Compressed air dryer
fj40charles
Texas
Make sure you get one that can handle your cfm needs. The first one you linked was only 10cfm. A lot of folks swear by adding a motor guard air filter immediately prior to the plasma as well.
How about these stats? What does 10 SCFM @ 100 psig compare?
My IR SS3L3 is rated for 10.3 CFM @ 135 PSI.
HANKISON COMPRESSED AIR DRYER
Model 8010
Serial 0302A-1-8909-3113N LR-40907
Rated Capacity 10 SCFM @ 100 psig @ 100F inlet air
MWP 175 psig
Min/Max ambient 35 F (2 C) / 110F (43 C)
VAC 115
Phase 1
Hz 60
Unit Fla 3.3
Compressor Fla 2.9
Fan motor amps 0.5
Max fuse/ckt breaker size 15
Fan motor watts 4
Min/Max volts Min - 104 Max 126 vac
Compressor HP 6-Jan
Compressor LRA 18
Min. ckt ampacity 4.1
Refrigerant R-12
Refrigerant charge 6.5 oz
Refrigerant suction pressure 34 psig
Factory test pressure 235 psig Hi/Lo refrig. side
Tank
Air mac 8273
Catalog 30
Gallons 1989
Year
Thomas instruments - Malnetek Century Electric Motor
A/C max 125 PSI max
Model HP 1500
P/N 170006
Manufacturing date 0690 13506
Motor
Part number 8-168498-02
HP 1.5
RPM 1725
volts 208-230 / 460
Time Continues amp 40c
Frame YA56Y
Type SC
Hz 60
Phase 3
Amps 4.8 - 4.6 / 2.3
