- Location
- United States
We’ve built two more very high quality 2F’s using Toyota rebuild kits including gaskets, bearings, oil pump, and seals. The only parts that are not Toyota are the pistons, rings and the new (not reground) camshafts. They’ve been bored .30 over and the heads have been milled to perfection and to increase compression. As part of the machining process the engines are throughly cleaned then after assembly they
are painted with several coats of semigloss hi-temp paint. $5500. These pics are from our most recent installation of the same type of engine build. I’m happy to answer any questions that you may have. Thanks Anderson
