Coil Recommendation to match with Ironman Foam Cell Pro
Montana
I have Ironman Foam Cell Pro Performance with a 1" lift front and rear that are about two years old. I recently added a steel bumper, and will be adding a winch. Normally I'd just upgrade to the matching TOY063C heavy Ironman coils, but Ironman does not stock the heavy springs standalone in the USA (a reason to choose a different brand for anyone else looking) and have not found anyone that will ship them to me outside the USA.
So while I normally wouldn't plan to mix a spring and shock brands on a coilover, I'm wondering if any other brands will work with the FCP, and if so, if anyone has a recommendation for a heavy front spring that would work.
Thanks for any guidance.
Follow-up. All the IM front coils have the same thickness and spring rate, just different lengths.
IM make it a bit confusing my calling them "light", "performance", "standard" "heavy", etc., and listed supported loads when they all have the same spring rate. I ended up putting on a set of new "mediums" I was able to get for a deal from another member, which gave me the exact height and rake I wanted, but adjusting the spring seat would have the same effect.
This may be old news for many, but figured I'd post it in case it can help anyone else.
