Absolutely, but you should think about putting a water trap inline for tools, and oil your tools regularly. CO2 is bad about moisture, nitrogen is tons better but doesn't compress anywhere near as well. I don't use tools off the CO2 tank personally, just a hassle to carry the extra weight when I can get by with other strategies.. just depends on your needs and experience.
Don't recommend 150psi for tools though... the fixed regulator I have has a spring you can swap out for different fixed pressures. That's going out the window as a friend can get me a variable regulator really cheap... just so you know it's an option.
