- Location
- United States
Forsale in Frisco Colorado is our Late (has trans spacer)1985 FJ60 $7,000. We have too many trucks and this one is up forsale. I will try and be as upfront and possible but please feel free to ask questions.
The Good-
Body and Chassis have 153K miles
Arb Bumper with Lightforce lights (not hooked up)
Gamivitti Expedition roof rack
Solar system with dual batter system
Rebuilt rear driveshaft
New exhaust with cat
Pfran LED,s
Newer FJ62 Radiator
All new coolant and silicon vacuum lines
New Troll Hole carb
Most fuel lines and fuel tank replaced
Brand new Toyota fan clutch and fuel pump
Rebuilt PS pump
Head has 30K miles on rebuild
Replaced motor less then 3k miles ago with a used motor all new OEM seals and oil pan (more on that later)
New Clutch
New Clutch Slave
Blue Sea systems power in rear compartment for fridge
New suspension (alcan springs with OME shocks)
Wheels and Tires (FJ cruiser steel wheels and BFG all terrains)
New side marker lights up front
Newish Toyota Aussie Style side mirrors
Interior is decent with factory floor mats (missing rear carpet)
All new belts
New windshield and gasket
New wipers
Hella H4 Headlight Conversion
Man A Fre Desmog kit
Man A Fre Sway Bar ball joint links
New Toyota Spark Plugs, Cap, Rotor, PCV
Pretty much new fluids in everything
The Bad-
I put in a new (ITM timing set and it is noisey. makes a knocking sound)
Front of the motor leaks as well as the rear main a little even though they are new OEM gaskets and new pan
Motor doesn't have the greatest oil pressure but runs well. Have taken it over the continental divide a few times since the motor swap
Has rust in places but is overall solid
Has a light coating of spray paint that matches the original color over the entire body (coming off in places) my girlfriends uncle went a little nuts after we committed to buying it and wanted to make it look a little nicer. Ha.
Front axle is a little leaky
My girlfriends Aunt owned this truck since 1991 and we purchased it to build into an over landing truck. I have put a serious amount of time and money into the truck at this point that far exceeds the asking price. I think what I am asking is fair for what you get in today's market. The truck is currently desmoged but I have the parts to resmog it if you so desire.
Asking $7,000.Located in Frisco, CO.
The Good-
Pfran LED,s
Newer FJ62 Radiator
New Troll Hole carb
Rebuilt PS pump
New Clutch
New Clutch Slave
All new belts
New wipers
The Bad-
