I posted a question some time back about Clutch chatter. Every thing is in adjustment and my 84 fj60 with 94k miles chatters with the 33s on at every take off. with my close to stock tiny little tires on; no chatter unless i'm on a really steep take off. (duh, I know, I know, taller tires need different gearing..an't gonna happen).
Looking at the clutch and flywheel area after removing the cover, the whole mess is covered with oil. Of course it has been leaking for years, however, the only oily area under there is in the clutch/flywheel area. Drips to the ground are from the weep hole at the bottom of the inspection cover and just in front of the cover at the oil pan. There is no oil coming down the oil pan not even on the trailing edge.
Questions:
1. could the chatter be from the oil leak which I think is the main seal or the cam freeze plug since the clutch area is so wet, (don't think this would happen with a oil pan gasket leak, right?)
2. If the original clutch is oil soaked but still good should I replace it anyway? I've told my mechanic to for sure find and fix the leak. He is going to put the ultra violet die in, run it around some and see where it originates from, (good sounding plan anyway) by-the-way with resurfacing the flywheel I'm looking at $450-500 in labor..yikes!
3. PO gave me a CCOT after market clutch ($240.00 invoice w/ it) I have a Toyota main seal but the bearings are also CCOT after market parts.
Should I still go oem and e-bay the after market stuff?
So that's it..I know there have been similiar threads, believe me I've been reading for hours, however, these questions did not seem to be covered, .thanks in advance for taking my clutch into consideration....
Going in tomorrow 9/21/05 he won't start on the job till Thursday 9/22/05.
HD
Questions:
HD
