Clutch not disengaging (1 Viewer)
I have a 70 series toyota land cruiser with a 3 three speed transmission. The clutch had started to slip so I went and replaced it. I beleive that I have gotten the friction disc in the right direction, I also beleive I have the proper throw out bearing . As well as the correct pilot bearing. I am first wondering if I installed the correct pressure plate. I have the three finger style plate. The clutch is grabbing just fine, it is very strong, the clutch pedal feels fine. The rod is adjusted about as far as it will go. I dont beleive I have air in the line, or that I need to adjust the clutch pedal. The problem is when I try and put the tranny into gear, it seems like the pressure plate is not disengaging. The tranny will not go into first gear, it just grinds.
My questions are, what is the symptom of a backwards friction disc. How do I know I have the correct pressure plate. I measured the pressure plate and it looked exactly the same as the old one. My guess is that the pressure plate is wrong. Or defective. I hate the idea of wrestling that transmission and transfer case back up there. This job has not been fun, the way it is looking is it will be coming down again.
No 70 series landcruiser comes with 3 speed tranny. Minimum is 4 speed the most 5 speed.:eek: Please take note.
the land cruiser is 1970
May have posted in wrong section, it has three speed tranny, I thought 70 series were made in the 1970's. Sorry for such a nob mistake.
