Never had to replace my clutch, yet. Knock on wood! But since the original has lasted over 25 years without a second's trouble, I'd certainly be inclined to put in another Toyota original. Why aftermarket clutch?
the high cost of the oem is my issue since i've heard good review of the exedy and less money so i am inclining of going this route.
rosco, do have a suggestion on what kind of exedy is good i use my truck as dd. exedy 1607118 is for hilux 2l-t, i my is 85 lj70 2l non turbo does it make any difference?
exedy clutch is made in Malaysia, so it is a popular choice among MalaysianIf the cost is less then you should consider exedy. Good enough clutch.
exedy clutch is made in Malaysia, so it is a popular choice among Malaysian![]()
thanks for all your input i will try the exedyI had the Sportstuff ,it was ok but ti got a littler heavy on my leg.Next time Im getting a standard type
I dont think the torque difference between a 2L and 2LT would be a concern.
Other owners with the bigger 6cyl engines use the same clutch for turbo and non turbo engines. I think the 2H and 12HT use the same clutch from Toyota
Im sure Exedy would answer your question if you are in any doubt.
If you went with the heavier duty sportstuff you would be ok for sure.But do you want the heavy clutch feel on a DD?
Ive always had good service from Malaysian and Taiwanese parts and I never hesitate to buy them if they are on offer.
Funny they are made in Malaysia.
Ordered exedy for my kzj71 project from Oz![]()
check this out http://man-a-fre.com/pa/omedakkarleafsprings.htm
Malaysia also manufacture OME dakkar leaf spring![]()
Yes ,we've known that for a long time.The springs were coming from Beltons but Ive heard they were getting someone else.
Is the quality up to par?
