Clearance question 305/45/22
Cal
Hi
I'm currently running 285/45/22
rims 22x10 offset +25
stock height
I would want to change to bigger tires 305/45/22 cause it looks better overall with the truck.
however, upon checking, my current set up with 285/45/22, the tires are already very near the wheel well on a full turn.
What is a possible solution so that 305/45/22 can fit?
because i've seen many who are able to run 305/45/22 tires but i think they have different offset wheels.
That's only a 32.8" tall tire, so you should be good. 25mm offset is about perfect, maybe a hair to small for such a wide tire, but likely workable. Worst case you may have to slightly massage some of the plastic fender liner with heat to fit.
Hi
stock height
Any pics of the current setup with the 285 tires and 25 offset?
sorry for the late reply,
How do I massage the plastic wheel well?
Here's the photo full turn,
Tire 285/45/22
Toyo StII
22x10 offset 25
I have like 5mm clearance, cant stick my finger in between
