looking at moving to oregon and this truck would be a waste up there
so im looking to trade for something 4x4
4x4 van, expo type vehicle
located in los angeles area
id really rather trade but since i have to list a price
32k
the motor alone was near 20k
Frame cut off from cab back and cab is 1997
Everything listed is BRAND NEW!
689HP Leon Patton/Patton Racing Big Block 454 bored to 460 full rolller motor 91 pump gas.
- TH400 Trans all 300M internals, manual valve body Custom TCI torque converter
- Dirt Tech front end with 12inch 2.5 KING coilovers and 12inch 3.0 KING Bypass and 2.5 bumps
- Rear 4 linked 16 inch 2.5 KING coilovers and 18inch 3.0 KING bypass and 2.5 bumps
- Desert Specialties sway bar
- Desert Specialties Hubs all corners
- Desert Specialties 9inch Rear end, 300M 40 spline axles, full floater, Strange 3rd member 5.49 gears spooled
- Willwood 6 piston Calipers all around with 14inch Desert Specialties rotors
- PWR coolers, HUGE 37" radiator, (2) 15" trans coolers, 1 power steering cooler
- Tommy Lee / Lee manufacturing power steering, Custom steering box, 2.5 hydraulic ram, Dirt Tech center link and tie rods notched frame for full travel
- (2)fuel cells, both Fuel Safe 32 gallons each
- 39inch BFG baja tires and 17inch Trail Ready Bead locks wheels
- (2) parker pumpers - Art carr shifter - pedals and steering wheel - ETC..
- Conversion one piece hood 2005 F150 front end, Bed sides 12inch flare
- All material is 4130 and F911 and Grade 8 hardware
This is the major parts list. I have everything for the motor, serpentine pully, ignition, headers, 1000 cfm holly carb built by Patton racing, etc..
No expense spared at all.
What is needed to be completed:
Firewall
Interior: Dash, seats, gauges, gps, shifter, switches, belts, pumpers, etc..
Plumbing: All hoses, radiator mounted, trans coolers mounted, fuel lines etc..
Wiring: switches and batteries, ignition, etc..
Drive Shaft
fiberglass mounted
Shocks charged and dialed in
32k
Firewall
Drive Shaft
fiberglass mounted
