I am unclear on part of the shimming process. If you don't know off the top of your head, what I am looking at can be found in the FSM pg FA-24 at the bottom where the shim formulas are shown in two boxes. The top box: LOWER SHIM THICKNESS E E=D-3MM is self explanatory, it is the lower formula that I am unsure of. It reads: UPPER SHIM THICKNESS F F=C-E. Specifically I do not understand what "total shim adjusting thickness C" is or how to get it. Hopefully one of you will be able to help, I'm starting the rebuild tommorrow. Thanks in advance for any time and thought put into this question.
