christo's rod end questions and install report (1 Viewer)
semlin
curmudgeon
north of 49
Hi, so I replaced the relay rod ends and installed the ome steering damper today. I am basically done but have some questions i woulde like answered before i tighten up.
should I even out the thread distance on the rod ends? the thread distance on the two relay rod ends was 1cm ps and 0 cm at the pitman end( it was tigh as it is possible to be). when i pulled the rod ends, the pitman arm end loosened up fairly easily, but the ps end took a lot of blaster and torch work work to turn it. I suspect that the last guy to do an alignment gave up on the frozen side adjusted at only one end, so I took the total of 1 cm of thread on the last time i was ps end and split it into .5 cm at each end. does this sound like a good idea? After my last alignment the truck has always pulled to the right a little more than I like. the alignment guy told me there was no more adjustment and he could not fix it. I think now i understand why :rolleyes:.
I used christo's replacement set and they come with metal wire spring clamps to hold the bottom of the rubberboot on. does anyone know if they are supposed to be installed like that or if they are removed before install? I left t5hem on.
are you supposed to fill the boots with grease? I looked inside and there was no grease other than a thin layer on the rod end so I filled them up with axle grease.
does 67 ft lbs torque sound right for the rod ends? That is the FSM spec but when I tighten them the boot is a lot more flattened and distorted than it was when I removed them.
As you can see my last 3 questions are potentially related :D
As far as a write up, I realize this is pretty basic stuff but this was my first time doing this job and I tried but could not find a write up beforehand and the FSM is farily useless and it would have helped to have one, so I will contribute some comments for those, like me, who don't know how to do this.
one comment is that Christo's parts look like very good quality to me and are nearly identical to the oem.
the OCT 7315A tie rod removal tool that christo and others here recommended worked like a charm on the rods end, but would not budge the dampoer bar ends. it took a bfh on the vice to get the steering damper ends out. they were so stubborn i wondered for a while if they were threaded into the rod end. it is good ome gives you replacements with the new damper because they are unlikely to survive removal intact.
if you do a rod end replacement, make sure you have something to break loose the old rod ends from the rod. the pitman end rod is not so bad because you can use the hole where the damper goes on as a lever point, but for the other rod ends you need something long and strong that grabs the neck of the rod ends. I assume most folks use a pickle fork? In my case I used a big adjustable wrench to grab onto the rod end, then a 24mm socket stuck over the end of the wrench and a 30 inch socket extensionon the socket to get enouygh leverage to turn the rod end (after cooking it for 5 minutes with a torch).
You also need a vice strong enough to really grab the rod and hold it, or else a big powerful set of vicegrips with a round mouth. Make sure the vice has a pipe mouth if that is your plan.
oh yeah, lots of penetrating oil before hand and a propane torch help too :D
I can answer one of those
One side is left hand thread and the other is right hand thread correct? If so you would defiantly want the exposed thread equal on both sides to allow full range of adjustment without having to remove one TRE.
No idea on the rest except for the torque, 67' pounds is the proper torque, if they are made with the proper taper they will not over seat, it could be excess grease swelling the boots or just that the new boots are designed differently? Do the boots look pinched? bulging? Tight to the touch like they are about to pop?
Semlin--
Thanks for this write-up/q. list as the relay rods and TRE's are my next upgrade on the 80 after the OME heavy that I am going to perform in the next month or so (have the fronts, going to order the rears when Christo get's back from CM05).
I was wondering, did you also consider the rods and TRE's that Marlin advertises on their webpage? I'm trying to figure out which set will be good for me (no rock crawling, occasional off-roading, mainly getting truck expedition ready)? Both look really beefy and I know Christo's products are superb in construction and customer support.
Any pics by the way of the install, or the final finished work? I'd be interested in seeing that too.
Thanks again.
Best
-onur
Akron, OH
onur
i did not consider other aftermarket. the slee set came highly recommended as being close to stock and that is what i was after. i am generally very leery about using any aftermarket after buying stuff twice a couple of time at the outset of ownership. i also liker to give slee some business when i can since he and robbie help people out on the board here (including me) frequently, and since he develops and stocks products for the 80 like no one else.
i did not take any photos during the process. I still have to do the tie rod ends so perhaps I will get a couple of photos then.
Thanks for the response Semlin...
I too agree with your assumptions re: Christo and Robbie's fine work on these boards (and the vehicles that are a testament to their love of the 80's).
Can you take pics of the rods installed on your truck, along with the relay too? I assume that Christo's is much beefier than the OEM, but also a perfect fit...correct?
Thanks again. THink you should divy up for a ROTW one of these days!!
Best.
-onur
AKron, OH
they are not beefier than stock that I can see. they are made in japan parts virtually identical to stock except that they do not have the 565 stamp on them. I'll take a photo of two side by side.
Thats funny simon,
I just replaced the ends on mine yesterday, well at least the drag link side. My relay rod was bent up from hanging the front end on a rock and somehow between Ben at Slee and I, I ended up with a shiny new drag link instead of the relay rod. oh well Now I just have to wait till tomorrow morning and see how fast they can get the relay rod to me. Planning on leaving tues afternoon and heading down to moab.
FWIW the new drag link is more than twice the thickness of the oem link, also it is not split and clamped like the oem style. solid threaded with a jamb nut. much better desing than oem IMHO. the added bonus here is if you replace the rods themselves you dont have to fight to get the tre's out.
Dave
dave
yes looking at how seized the tie rod ends look that i have to try to do next weekend a new set of rods is sounding better. Plus my relay rod is slightly bent. plus in order to get the steering wheel centred I ended up with only about 3mm of exposed thread adjustment left at each relay rod end.
so does the steering loosen up in a little while after new rod ends are installed? it is more precise but also noticably heavier, but maybe that is the OME stablizer?
