Chewbacca's Birfield Grease Guide
Found a new grease to add to your list, it's made by Shell. It's called Shell Gadus S3 V460 D2, it's rated as a NLGI 2 grease with 3% moly. They also make a 5% moly, that part number is Gadus S3 V460 XD. Here are some links to Shells info on this grease. http://s04.static-shell.com/content...ge-brochures/shell-gadus-s3-v460dbrochure.pdf and some more info http://s06.static-shell.com/content...ads/pdf/shell-gadus-productfamilybrochure.pdf I found it at a local Shell dealer for $39.00 dollars, for a case of 10, 14OZ tubes.
Good stuff, I have added it to the list. Thanks!
That's a hell of a good price too, going to have to find my local shell dealer
T
This is what my local Napa carries.
I can see the Valvoline Pallidium you need right in middle.
Look no Further.
Each Knuckle holds about 2 Tubes.
I used a putty knife to fill the birfs and a grease gun to fill the knuckle bodies.
Using Glove and lubes makes me feel uncomfortable.
I used a tub of Timkin Bearing Grease with my Timkin Bearings.
Yeah just seeing what's out there locally for when I do my axle overhaul in a few months.
Can we update the Valvoline SynPower option on the first page? I checked the MSDS and it says that it contains 2.5% Moly.
Section 3, Page 2 of 13. Here's the link to search for SynPower Grease. The website hides the link to the PDF so I can't link the file directly.
MATERIAL SEARCH
In contrast, Valvoline Palladium is 3%.
For those who are having difficulty sourcing Palladium, SynPower looks to be a good option? Is the 0.5% difference significant? As an earlier post mentioned, could SynPower be the best for both general use and the front Knuckle?
"Sir I stopped you because you were taking a picture of your junk while driving. Can you step out of the car please?
:grinpimp:
Look no Further.
Putty knife? Dude, we're more refined than that. Use the kitchen spatula, much better than a rigid putty knife :hillbilly:
MATERIAL SEARCH
Updated, thanks!
Chewbacca, I have a couple of questions for you.
Which one of these greases do you recommend based on your findings, regardless of price and do any of these work for greasing applications such as the u joints? Sorry I do not have a FSM so I dont know what is required. Thanks
For u-joints, I would definitely recommend the Amsoil synthetic moly grease, the stuff is incredible.
There's probably a bunch of great choices for the Birfields, the Valvoline VV985 is probably a decent one that's not too hard to find. Greases that have tackifiers are definitely good.
Ok thanks much.
