Micah, was your truck going into "limp home" mode when it was throwing that code?
I recently purchased a 98 LC, and on the coldest day of the year it started, shut off, started again with a little throttle input, and drove fine. Upon restart after reading the code at autozone it went into limp home mode. It is throwing P1126 code, and continues to operate in "limp home" mode. At this time I am unable to check resistance per the image shown above. Is it a gamble to replace the throttle control motor, could it be a bad harness or ECM?
Thanks for the help! It is much appreciated!
***EDIT***
Tried to add pics and deleted my update.
Loose connector at my throttle control motor was the culprit. I had the TB done 2 months ago and I guess it was disconnected and not seated when it was reconnected... maybe.
I went searching the internet for a replacement throttle control motor and realized that I may have been looking at the wrong connector, I popped the hood and the connector at the throttle control motor wasn't seated. I clicked it, cleared the code, and now the truck runs like it should.
It is the connector in the foreground (right side of the throttle body, when looking at the engine)
