Hello. I am up in western nc. I am going to sell my fj60. It’s silver with a gray interior. I have done a ton of work to it. I’m in Australia now but I’ll be home next week. It has a Holley sniper fuel injection. Brand new specter interior. New ome lift, new bfg 33’s. I‘m going to put a new cylinder head on it next week and I need to bust some surface rust on the frame. It has 174k miles and a dealer installed sun roof.
Replaced rear axle bearings and diff seal, axle seals
Installed all new brakes on rear axle
Installed new brakes on front axle
New brake master cylinder
Rebuilt steering knuckles and replaced all axle bearings and seals front axle
New ome lift kit
New shackles
New sway bar
New fuel filter
New thermostat and gasket
New water pump
New alternator
New fuel pump(electric)
New water pump lines
New fan clutch
New lug nuts
New oil pump
New 33” bfg all terrain’s ko2
Tune up
New oil and coolant sending unit’s
New front grille
Replaced lower radiator coolant line
Replaced engine oil cooler soft lines
New vacuum lines
New fuel sending unit
New specter vinyl seats
New carpet kit
New floor mats
New heat riser in intake exhaust manifold
Interior floor body work
New pedal pads and shifter knob
Installed new dui hei distributor
Valve adjustment
New Sony radio and Polk speakers
New side marker lights
New rear light lenses and installed led lights
Plane down intake/exhaust manifold
Rebuilt transfer case
New charcoal canister
Replaced rear axle pinion seal
New battery
New catalytic converters
New muffler and tailpipe
Fuel injection and fuel pump
Header
New brakes, rotors, calipers, shoes, hardware, cylinders
New clutch master and slave cylinders
thanks, troy
