Changing the belts on my '85 FJ60
South Carolina
I did some research in preparation for changing my drive belts. My Chilton manual has the topic listed in the General Maintenance section, and devotes approximately 1/2 page to the subject, so I wasn't expecting it to be too difficult. Many of the posts I found made the process much more complicated than it should be. I completed the process yesterday and thought I might post the steps I went thru. This was my first time changing the belts so it took me slightly longer than it should have. I don’t claim to be an expert and the process I outline below is just my opinion. Refer to the experts for the official process. Here's what I learned:
Used OEM belts. Amazing how much thicker the OEM’s were than the belts I was removing.
  • Belt, V, COMP.DRIVE - Toyota Part #993321125078
  • Belt, V, P/S VANE PUMP - Toyota Part #993431157077
  • Belt, V, AIR PUMP - Toyota Part #993431112077
Needed just a handful of tools. Includes 10, 12, and 14mm sockets. [See Pic 1]
I did not need to cut/bend anything on the fan shroud to feed the belts in/out.
Made sure not to over tighten the new belts.
Alternator:
Remove the Vane/Alternator belt by loosening the bottom pivot bolt (needed wrench on both ends) on the alternator and loosen the top bolt located in the adjuster bracket. I did not loosen anything else. Alternator then turns in allowing the belt to slip off.
Fed the old belt past the fan. Done.
Air/Smog Pump:
Removed the two hoses that were in my way. Not really necessary but made access easier. Hose removal took one minute.
Loosen the 12mm bolt. Bolt is located just under the air pump wheel, above the lower part of the belt (inside the belt loop). Found with fingers since I could not see it. The nut on the back is much harder to reach (or see) but the job was easier after I constructed a 24” extension with a ratchet swivel adapter and a 12mm socket attached to the swivel end [Shown in Pic 1]. Just needed to keep the nut from turning while I loosened the bolt from the front. I was very careful not to have the nut fall off the back. My truck is not de-smogged and retrieval would have been difficult.
Loosened the top bolt in the adjuster bracket to the point I could pull the adjuster mechanism off the back. That was it. Turning the pump in to get the belt off proved challenging because some hoses were basically petrified and unworkable. Careful not to break anything, I ended up putting a T bar (from my spare tire kit) with a pipe extension under the pump just enough and used the adjuster bracket as leverage to rotate the pump in to pop the belt off. [See Pic 2] Done.
AC Compressor:
I did not have to go under the truck for anything other than retrieving a dropped tool. I was able to loosen the two bottom pivot bolts easily from above.
The third bolt located in the adjuster slide was hard to see and I ended up removing it in order to get the compressor to rotate. Easy enough. Not sure if I needed to remove the bolt since putting it back in was difficult but eventually accomplished without the ability to see to line up the hole.
I did not mess with the Tensioner wheel below.
Replacing the belts:
AC Compressor:
While the belt was off, I turned the compressor wheel to check clutch.
Standing with my left foot on the frame inside the engine compartment, I looped the belt under the crankshaft wheel and onto the bottom of the compressor wheel, turning the compressor wheel clockwise while gently pushing the compressor in. The belt didn’t need to be fed past the fan and popped on easily. Make sure the belt is on the top side of the tensioner wheel when installed.
Pulled the compressor towards me to tighten the slack on belt, and tightened the two pivot bolts.
Put the adjuster mechanism back together and tightened the adjuster bolt.
Air/Smog Pump:
Feed the new belt past the fan.
Looped the belt under the crankshaft wheel, over the water pump, and then from the bottom of pump wheel, turned counterclockwise while using the lever I created to turn the pump in. [Shown in Pic 2]
Put the ratchet extension on the nut located on the back of the pump and tightened the bolt from the front. The petrified hoses I mentioned earlier pushed the pump back in place taking up any slack in the new belt.
Put the adjuster mechanism back on the top bolt, tightened the adjuster bolt and hand tightened the adjustment screw.
Alternator:
Loop the belt under the crankshaft wheel, around the P/S Vane pump and work over the alternator wheel.
With new belt on, pulled the alternator towards me while tightening the top adjuster bolt.
Then tighten the pivot bolt. I stripped this bolt while loosening it earlier and had to remove it to rethread the bolt and nut.
Put the hoses I removed back on.
Ready to start her up and adjust/fine tune belt tension if necessary.
Thanks for the write up. Where did you order the belts? I'm looking for the same ones.
EDIT: Found them online at Toyota.
Used your guide to change my belts out today after my Air/Smog pump belt gave out.
Toyota dealer near me says they no longer carry the #993431112077, so I went with a Gates TR22448 which fit alright.
I ended up taking the air intake hose off to give me some more room to pry the smog pump up to get the new belt on using a similar method with a tire iron and the adjustment bracket.
I found I couldn't hold the back side nut of the smog pump pivot bolt with a socket due to an engine mount bolt. I stuck a 12mm box end on it and was able to hold it steady while using a socket on the front side.
When installing, your guide says to tighten the pivot bolt first for the smog pump and then tension the belt. I tried to tension first and found the belt blocks the pivot bolt, so I had to go back to do it the way you recommended.
Thanks for the guide.
