Hello 100 series forum, i spend most of my time on the 80 serires forum, but i was hoping to get some help here. Today i finished replacing the timing belt on my wife's 2003 truck , which has the 2UZ-Fe motor in it. I had the service manual, and the guide from ih8mud.
The job was long and annoying, but not overly difficult. I opted to replace the water pump, timing belt tensioners, spark plugs, and thermostat while i was in there.
So after everything was back together, I started the truck, and it started up just fine and sounded ok. It seems to run fine and has normal power. After a few mile test drive, it has developed a slight "ticking" that i don't remember before. I spun the crankshaft around to 0 degrees TDC, and popped enough screws to peek insde the two top timing covers up top to verify that the timing was still good. The timing appears to still be fine according to the marks on the two cam gears.
also, i have four OBD codes come up P0171 and P0174 two times each. They are "system too lean bank 1" and "system too lean bank2"
how badly did i screw up and what should i do to fix it?
