SOLD Central TX, ‘87 FJ60
Year
1987
  1. 60 Series
Texas United States
Mileage
238000
Color
Brown
Back up for sale. Runs great! Desmogged, Base lined with all new fluids/grease/gear oil and fresh clean gas and new fuel pump. New plugs and plug wires. Transfer case was redone at some point but they used rtv to reseal it. Shifts and operates great. Header installed with carb rebuild, along with new exhaust pipe and muffler. Exhaust needs to be done better, I just did a quick job to get it inspected. The exhaust works fine, just not the ideal setup. Sound deadening throughout the entire tub from the fire wall to the rear hatch, inside doors and rear quarter areas. PO was prepping it for paint but ended up deciding to sell, that’s why it looks silver, it’s actually the Copper color code under the trim and chrome. I have gone over the body and the only rust is in the rear quarters and some spots on the bottom of the doors. Cleaned fuel tank and lines, rebuilt carb, knuckles, brake lines, fuel pump, aluminum champion radiator, thermostat, new water pump, new fan clutch, new 555 TRE’s. All OEM parts. New 33” BFG, with ~500 miles. Newer dash pad, with one small crack. New coolant hoses, new Koito H4 headlight kit. Cleaned and lubed both front lock out hubs. Upgraded Euro spec mirrors. Upgraded 80 series rear wiper arm and new sprayer. Rust in rear quarters. Could use the c-channels redone. Used, but low mileage OME 2” lift installed a month ago. Has BOSS air bag kit in rear. Everything functions as it should. No radio or speakers. Rear main weeping a bit small quarter sized spot after about 3-4 days, needs replaced. Small crack in newer windshield. Drip rails look great but could use a reseal. Bought this last year, but some more life happened and I need to sell. Great starting point for someone that wants to drive one as they work on it. Not much downtime to fix the things on this one. Ready for daily duty with some new leaf springs. OME shocks and steering stabilizer have plenty of life left. I can get whatever pictures anyone needs/wants and also a cold start and idling video. This is a strong running 2f. I can get compression numbers as well. I have a ton of receipts of items and work done. $11k OBO
Did this sale go through?
