uHu said:When driving on snow or ice, it's always better to have the CDL on, EXCEPT when manouvering with sharp turns when you don't need the extra possibility for traction. It gives you more stability, easier to keep the track, and easier to use the brakes in a controlled way. It's better even when you have ABS because there will be less work to do for the ABS.
Then, when going downhill, if you stay in a low gear, the braking force of the engine will most probably be too high, resulting in lack of grip and skidding/slipping. This is of course dependent on road/track conditions and the angle of descent. When you loose traction this way, it means that you do not have enough grip to reduce your speed down the hill, or even to keep the current speed. The best thing to do is to NOT use a low gear, and instead use the brakes (with ABS). That way you will have enough grip to steer at the same time. And praying that the hill is not too long, or as slippery all the way, or doesn't get steeeeeeeeepeeeeeeeeeeeeerrrrrrrrrrrrrrrrrrr....
So, Big Bert, next time: CDL on, Hi range, D(rive), if it's that slippery.
Otherwise, if not slippery, normal rules apply, i.e. low gear down hill.
Good luck
Great advice though me not want CDL on especially downhill and icy. CDL on the suspension can settle especially turning.
