CC Meeting - November 10, 2011 *NEW LOCATION*
Indeed, don't feel bad Christian, we've all done the same, or worse. :)
Like tightening your alternator belt with a prybar, and having it slip and then jamming the prybar in your eye, severing the tear duct, and going for emergency surgery worse?
Or sliding your axle back in, and getting your fingers jammed between the flange and studs, unable to move it back out (because you really jammed it back in there with a pooched bearing) only after enough blood has drained from your hand that it's thin enough now to move it back out worse?
Or being really excited that your new engine is installed and ready to roar, as you excitedly run around plugging wires in, completely forgetting about that thing called 'firing order' worse?
Or removing the transfer case and transmission, and forgetting to put the jack in place as you undo that last bolt worse?
Or trying to remove the calipers on your rusted out piece of s*** Nissan Hustler (that you bought the same day after recovering from emergency eye surgery, with a huge patch over said eye, yarrr!), and just 'losing it' in frustration, then beat the caliper off with the biggest fxxxing hammer you could find worse?
Or losing a rear wheel as you go down Canada Way, because the night before you checked your brakes and forgot to torque that one particular set of wheel studs back on, just had them finger tight worse?
Or try to remove a rear brake drum after losing a rear wheel and have the drum smash against the sidewalk, busting the s*** out of all your brake components inside, making it impossible to remove the drum, so you grab the biggest fxxxing hammer you have lying around......
That kinda worse?
That kinda worse?
HAHAHAHAHA best post I have read in months!
I can relate to a lot of them too.....
LOL! Thanks Jeff you now have made me feel much better!
Christian, you should wreck your truck more often. I actually won 2 times in the draw!
And my kids and I won 3 times!
Hey- the boss already has a copy of 'Best Hikes and Walks' in BC I won- anyone want?
I'll take it, if it's not spoken for.
Before every meeting, we should start breaking something on Christian's Cruiser? :D
