I concur with 2000's comments...
***Thank you for your comments and advice. The next rack would definitely be cheaper to build and there really weren't any issues with this one other than the front being shorter than originally designed, which meant the basket couldn't be built and used.
***Yes, a rack should hold stuff securely. That was the first thing I wanted in the rack. I wanted to fill it with wood, gear, tires if necessary and have it hold those securely. There are plenty of platform racks on the market already. I didn't want another place for an air mattress
***It does not cover the sunroof. The grab bar section should be at least 6" longer (7' overall length) and would accommodate the removable basket section. In an earlier thread, I talked about the fabrication problem that lead to the rack being shorter.
***I'd like to think that it is more than just a flat piece of metal. It is sculpted around the upper and lower side rails and has nice bends in between the upper and lower rails so air will flow around it easier.
***If I ever get my rig back from the gear shop, then I will install this thing and finish it up. Thanks again for your input.
