Can anyone tell me about the CAV or similar converions available for my 2 filter 78 series troopie? I hear they can be a great sucess allowing the use of much cheaper spin-on filters but I am also vaguely aware there my be some drawbacks, increased restricton in fuel supply / fuel starvation? I thought I also read a recommendation to add an electric fuel pump?
If it is a good upgrade then who supplies them (I'm in West Australia)
I'd be grateful to anyone with some experience to set me on the right path.
The filters are cheaper but the original type can be bought at Malz cheap enough,I think they are $19 for a Ryco compared to the CAV type at $8. Its going to cost $200 approx to replace what you have.
I considered it but it would take a lot of filter changes to get my money back.
I dont believe electric fuel pumps are needed . The FSM says you need 2psi in the fuel lines and 7 psi internal pressure inside the fuel pump(adjustable I think).
Besides that ,the injector pump is already capable of pumping 54 litres an hour at 2000rpm.
At those engine speeds you can only use about a 3rd of that under very heavy going.
I have a combined filer /water separator CAV type on my other landcruiser and no problems with fuel restriction.
Any diesel shop will sell them as well as Coventrys and
ebay.
You can also get an adapter that fits onto your existing filter head and allows you to use the cheaper filters.
These cost about $120 and would still take a lot of filter changes to make it worthwhile.
If you decide to change them,make sure it will fit,there is limited room from the inside fender and the master cyls
