SOLD Carthage NC late H151F
  1. 70 Series
  2. 80 Series
  3. LX450
  4. 100 Series
Carthage, North Carolina United States
PENDING Was going to use this in my 80 behind a 14BT but decided to keep the A442 auto. Later H151F with improved synchro rings. Includes transfer case, 1hdt bellhousing, and starter. Has a few broken plugs from being moved around and is missing gear shifter, one switch on the t case, and control rod from range shifter to lever. Also could use new studs on the rear output flange as some are spinning and have damaged threads. Was told this was part of an engine swap package from cruiser heaven but P.O. wanted an h55 and split case instead. I have shifted through the gears and t case high/low while rotating the input and everything seems smooth. Asking $3900 but feel free to make an offer. Located in carthage NC 28327 usa about an hour SW of Raleigh.
