Carpet Hooks/Anchors
Yorktown, VA
I picked up a set of weathertechs for my 03 and loved them until the anchor pulled out of the carpet. Is anyone aware of a repair for this? Is there a new ring that can be installed in place with a bigger outer diameter but the same inner diameter?
Cool. I hoped there was already a solution. Is this an oversized one or the same size? Will I need to pull up the carpet to access the bottom to clip it in place?
It's a two piece clip. You need to undo one or two plastic trim pieces to lift the carpet just enough to scoot the bottom piece into place, and then the top snaps in through the hole in your carpet.
I hope this is a piggyback more than a hijack.
Does anyone know how many of these Carpet clips should be in my 06 LX? I currently have one in the drivers side and none on the passenger side. I have Lund Catch-All floor mats with a grommet that matches the one clip I have. There are smaller grommets that look like they should match three more clips (one additional on drivers, two on passengers) but are too small for the OEM clip I have (same as posted above). I also have offset holes in my carpet below these other three spots where it looks like there once might have been clips but they’re no longer there. I’d love to find some clips that match up so my mats stop sliding around. Are there smaller OEM clips that have been lost? Please let me know if anyone has any info or suggestions thanks.
