OregonCruzer
Póg mo Thóin
I vote in favor of changing the nomenclature "rings" to "almost spheres if it wasn't for the hole in the middle", which could then be shortened to "asiiwfthitm" for ease of speech.
Somewhere between -30% and +15%. Depends on how the airpump underneath the carb is built.Jim C. said:
The venturis are not supposed to be serviceable.
But they can be removed and changed. The largest venturis used are the 31/35 seen in the pics. but it is possible to build a carb w/ 33/35 or even 35/35 if one were so inclined. The carb will work, as long as the venturis are smaller than the 38/40 throttle body.
The parts have to be sourced from other parts carbs, they were never available as service parts.
Common sizes are 28, 31, 33, 35mm.
What kind of performance increase will this provide?
Varies by year and market.I always thought he stock venturi size was 38/40.
Stock FJ60 carb is almost the biggest that is readily available. 75-76 USA carb is biggest CFM available, around 425.I am under the (mistaken??)impression that the most airflow that can be provided is with the stock carb. IF a person was to put 2 35 rings in a carb. Would that mean that the weber 38/38 would have 2 38mm venturis leading to the engine VS the aisin haveing 2 35mm venturis. Thus allowing more airflow.
Very punny.I must not be seeing the hole picture.
Jim,
Great info.
So have you ever done a real world Bionic carb and was it really worth junking out another carb for the venturis??
Thanks for your expertise.
John
Lead SD
What model # for the cruiser? I had a model # 2100 on my 40 once......what a flop. Rochester was a little better but a hack job was in order for a fit.If you want a carb that Hauls Ass get a HolleyThats what I have on my Thunder truck and it'll get 2nd gear scratch
some what economical too
The extra CFM is only useful if the airpump underneath the carb needs the additional airflow.So have you ever done a real world Bionic carb and was it really worth junking out another carb for the venturis?
The weber 32/36 is a progressive 2bbl, like a 70-74 F carb. But it is a very small carb for a 4.2L engine. It will not run the engine on the economical primary, so it is usually into the richer secondary. And even that is not really enough for street driving loads, so then the power valve opens, adding more enrichment...so if the Weber is "weaker/lame-er" how could your gas mileage decrease when using one. Are they less efficient? or is it just a figment of the imagination.
No wonder.... that carb is from the 50s.... used on 100hp or less......
