Can't find: replacement blank for suspension select/height control module (have deleted air) (10 Viewers)
Santa Cruz, CA
Hi Guys - I know I've seen it here but for the life of me (and a lot of time searching) I cannot find the right combination of terms to find the blank people put in the suspension selection area on the center console. Can anyone help with a link?
Also: someone here put a phone mount on the blank and I'm looking for that solution - SICK of the vent-mounts we've had going for like 13 years now... Any suggestions there would be great.
Last: I pulled all three fuses when I did the airbag delete a couple weeks ago and no lights, but a quick question: will unplugging the center-console suspension selector trigger one? Or is that whole part of the harness now dead/inactive?
As always, my thanks for the info. - Maka
I put this little pocket in the adjustable suspension spot:
TOYOTA 58839-60040 Console Box Hole Cover https://a.co/d/aU1nGmL
Good for holding smaller items like chapstick or whatever else fits. Blue Dog Design also has some 3d printed parts that replace the entire wood trim piece around the tcase lever. You can option cup holders, switch panel cutouts, or just have it be blank.
If your dash doesn't have the H, N, L Height Control lit up now, you should be fine to unplug that little switch/dial without issue. It's easy enough to pop that unit out and unplug it to test if you'll get any unwanted dash lights.
I have the insert for two Toyota style small switches. One is for the relocated gmrs radio and the other is for a light bar. The phone mounts shown aren't what I'm using currently, but I am using 67 designs phone mounts on the ORS bracket now.
An alternative is to replace the shifter console with a double cup holder, or single cup, or switch panel.
Take a look at www.BlueDogDesignwerks.com
It gives you more options if they fit your needs.
Great setup!! What are you using for your mic plug?
I don't remember where I bought it from, but it's referred to as an RJ45 UHF socket or passthrough. Just make sure you get the smaller Toyota style switch size.
