- Location
- United States
Canadian BJ70 LX Diesel 1985 12V Left-Hand Drive. 302,000 KM/187,654 Miles. 2nd Owner. Delivered new in Richmond, B.C., December, 1985. Vehicle is in Burnaby, B.C., licensed and insured, U.S. import eligible. Garaged since the egg. Unused 4-6 months each year. Usual body corrosion cut-out and re-metaled, full re-spray. Suspension replaced with O.M.E. 2.5". Chassis solid. Original sale document, manuals, etc. in-hand: sold for C$14,997.00 in November, 1985. Exchange for late model TOYOTA truck extended or crew cab, cash either way. Cash value C$13,800.00.
All mechanical work by TOYOTA technicians. This is the best of the best for condition and appearance, none better.
the good: unmolested, clean, straight, not off-road. Uses no oil between services, the usual one-drip-per-day when in use.
the bad: left side rear window defroster works right side not working, rear wiper works but lamp in switch has failed. Everything else works. Driver's seat worn-through at edge. Small rip at top of rear seat vinyl. Antenna tired. CD player not functioning (never has). Paint worn on roof gutter where carriers attach. Pin hole corrosion at extreme ends of fenders. Thermostat is (O.E.M.) 17 ohm, should be 28 ohm, but functional (to be replaced at a future service).
These works only performed since 1985, receipts in-hand:
-servicing at 5,000 KM increments, including oil, coolant, filters (air, oil, fuel), transmission & coolant fluids, chassis/wheel bearings/prop-shaft lube, battery maintenance, and any and all service as required
-regulator 1990
-replaced driver's side wing after hit by errant female motorist (undetectable with TOYOTA O.E.M. wing) 1996
-headlamps (upgraded) 1988
-belts, hoses 1994, replace radiator 2006, replace water pump 2000
-injector service 1988, 1993, 1999
-exhaust, tail, gasket 1991 & 2007
-adjust valve clearance 1988, 2007
-pilot bearing (warranty) 1988
-ambulance door check-strap 2006
-tires 2000, 2010
-brakes 2006
-full knuckle rebuild including coating, gaskets, felt and leathers, 2009
-replace passenger seat belt 2006
-marker lamp 2007
-OME 2.5", bushings, stabilizer, pins, steering, swaybar links, fuel primer pump (new), rebuild alternator, rebuild starter 2007
-fuel tank cap, thermostat 2008
-remove fenders, grit blast, prime, paint and box-liner 2006
-windscreen motor washer 2006
-spare set FJ wheels and tires, 95%+ 2008
-replace tires MICHELIN LT-X 2009 now 95%+
-steam clean chassis & 2-part paint, box liner below apron, on deck 2007
-batteries 2010
PM me for link to images.
Call or e-mail me, Tim Ellis on 604 716 1240 if interested.
-regulator 1990
-tires 2000, 2010
-brakes 2006
-marker lamp 2007
-batteries 2010
