Can you guys give me some input on this service history?
GA
Flying out to pick up an LX early Thursday morning. The service history looks great but having you Mudders take a look never hurts. If anything pops out at you let me know. Also anything I should be addressing immediately after purchase?
Here it is:
Dealer Reported06/27/2013Metro Lexus964970449195TECH FOUND CD PLAYER NOT OPERATING AT ALL,RECOMMENDS REPLACEMENT,GUEST DECLINED CUSTOMER STATES: CD PLAYER IS NOT PROPERLY FUNCTIONING, PLEASE CHECK & ADVISE. - ADVISE IF DIAGNOSTIC TIME REQUIRED
Dealer Reported06/27/2013Metro Lexus96497044919590,000 MILES OR - 78 MONTH MAINTENANCE SERVICE - 90,000 MILES - OR - 78 MONTH MAINTENANCE SERVICE - 96490 BRAKES: FRONT ARE *NEW* REAR @ 7MM - RECOMMEND REPLACEMENT @ 3MM PAD THICKNESS.TIRES: FRONT @ 7/32 REAR @ 6/32 - RECOMMEND REPLACEMENT @ 3/32 TREAD DEPTH.CHANGE ENGINE OIL AND FILTER ROTATE AND COMPUTER BALANCE TIRES REPLACE ENGINE AIR FILTER INSPECT FR
Dealer Reported06/27/2013Metro Lexus964970449195IT IS OUR PLEASURE TO PROVIDE YOU WITH COMPLIMENTARY VALET AND A LEXUS LOANER. A IT IS OUR PLEASURE TO PROVIDE YOU WITH COMPLIMENTARY VALET AND A LEXUS LOANER. AS A REMINDER THIS SERVICE DOES NOT INCLUDE FUEL, THEREFORE, $14.00 WILL BE ADDED TO INVOICE FOR FUEL RECOVERY.
Dealer Reported06/27/2013Metro Lexus964970449195COURTESY CAR WASH: INCLUDES EXTERIOR WASH, VACUUM FRONT MATS AND CLEAN FRONT DOO COURTESY CAR WASH: INCLUDES EXTERIOR WASH, VACUUM FRONT MATS AND CLEAN FRONT DOOR GLASS AND WINDSHIELD.
Dealer Reported06/27/2013Metro Lexus964970449195METRO LEXUS COURTESY INSPECTION
Dealer Reported06/27/2013Metro Lexus964970449195LOANER VEHICLE. WE WILL NOTIFY YOU WHEN YOUR VEHICLE IS COMPLETED. PLEASE PICK U LOANER VEHICLE. WE WILL NOTIFY YOU WHEN YOUR VEHICLE IS COMPLETED. PLEASE PICK UP YOUR VEHICLE AS SOON AS POSSIBLE. IF THE LOANER VEHICLE IS NOT RETURNED WITHIN 24 HOURS OF NOTIFICATION, A FEE OF $50.00 PER DAY WILL BE ASSESSED
Dealer Reported06/27/2013Metro Lexus964970449195TECH NOTES THAT VIBRATION IS NO LONGER PRESENT,CORRECTED WHEN BALANCED THE WHEEL CUSTOMER STATES VIBRATION WHEN DRIVING AT HIGHWAY SPEEDS AROUND 60MPH, PLEASE CHECK & ADVISE
Dealer Reported06/27/2013Metro Lexus964970449195VALET/SERVICE NOTE METRO LEXUS VALET DRIVER ADVISES NOTICED BRAKE PULSATION WHEN BRINGING CUSTOMER'S CAR IN FOR SERVICE, PLEASE CHECK & ADVISE
Dealer Reported06/27/2013Metro Lexus964970449195REPLACE FRONT BRAKE PADS, SHIMS AND HARDWARE, AND REPLACE ROTORS UPON INSPECTION TECH REPORTS FRONT BRAKES @ 2MM, RECOMMEND REPLACE @ 3MM PAD TKNS, FRONT ROTORS TOO WORN/THIN TO BE ABLE TO RESURFACE WITHOUT GOING BELOW MINIMUM ROTOR THICKNESS SPEC. TECH RECOMMENDS REPLACE FRONT BRAKE PADS, HARDWARE, ROTOR ASSYS AT THIS
Dealer Reported06/27/2013Metro Lexus964970449195REAR BRAKE ROTOR CUT AND BRAKE MAINTENANCE UPON INSPECTION TECH REPORTS FOUND PULSATION FROM REAR BRAKES WHEN APPLIED. RECOMMENDS RESURFACE REAR ROTOR ASSYS TO ELIMINATE EXCESSIVE ROTOR RUN - OUT CAUSING PULSATION & PERFORM REAR BRAKE PAD/CALIPER MAINTENANCE SERVICE
Dealer Reported06/27/2013Metro Lexus964970449195APPLIED 97 LOYALTY POINTS TO SERVICE VISIT,PLEASE SEE ""LESS INSURANCE"" LINE ON BILLING NOTE; PLEASE APPLY ANY METRO LEXUS CUSTOMER LOYALTY REWARD POINTS CUSTOMER MAY HAVE AVAILABLE AT THIS TIME. THANK YOU
Dealer Reported09/13/2012Metro Lexus91321043277685,000 MILES OR - 74 MONTH MAINTENANCE SERVICE - 85,000 MILES - OR - 74 MONTH MAINTENANCE SERVICE - 1 BRAKES: FRONT @ 4MM REAR @ 8MM - RECOMMEND REPLACEMENT @ 3MM PAD THICKNESS. TIRES: FRONT AND REAR @ 8/32 - RECOMMEND REPLACEMENT @ 3/32 TREAD DEPTH.CHANGE ENGINE OIL & FILTER ROTATE TIRES CHECK AND CORRECT TIRE PRESSURE INSPECT AIR FILTER INSPECT BRAKES INS
Dealer Reported09/13/2012Metro Lexus913210432776COURTESY CAR WASH: INCLUDES EXTERIOR WASH, VACUUM FRONT MATS AND CLEAN FRONT DOO COURTESY CAR WASH: INCLUDES EXTERIOR WASH, VACUUM FRONT MATS AND CLEAN FRONT DOOR GLASS AND WINDSHIELD.
Dealer Reported09/13/2012Metro Lexus913210432776METRO LEXUS COURTESY INSPECTION
Dealer Reported09/13/2012Metro Lexus913210432776LOANER VEHICLE. WE WILL NOTIFY YOU WHEN YOUR VEHICLE IS COMPLETED. PLEASE PICK U LOANER VEHICLE. WE WILL NOTIFY YOU WHEN YOUR VEHICLE IS COMPLETED. PLEASE PICK UP YOUR VEHICLE AS SOON AS POSSIBLE. IF THE LOANER VEHICLE IS NOT RETURNED WITHIN 24 HOURS OF NOTIFICATION, A FEE OF $50.00 PER DAY WILL BE ASSESSED
Dealer Reported09/13/2012Metro Lexus913210432776VEHICLE(BLK,LX470,GX470) COMPLETE EXTERIOR/INTERIOR DETAIL
Dealer Reported01/04/2012Metro Lexus85240041696680,000 MILES OR - 70 MONTH MAINTENANCE SERVICE - 85,000 MILE SERVICE - 85239 BRAKES:FRONT @ 4MM REAR @ 8MM - RECOMMEND REPLACEMENT @ 3MM PAD THICKNESS. TIRES:FRONT ARE *NEW* REAR @ 8/32 - RECOMMEND REPLACEMENT @ 3/32 TREAD DEPTH.CHANGE ENGINE OIL & FILTER ROTATE TIRES CHECK AND CORRECT TIRE PRESSURE INSPECT AIR FILTER INSPECT BR
Dealer Reported01/04/2012Metro Lexus852400416966METRO LEXUS COURTESY INSPECTION
Dealer Reported01/04/2012Metro Lexus852400416966TECH CHANGED,MOUNTED AND BALANCED TWO NEW FRONT TIRES UPON INSPECTION FRT TIRES ARE WORN WHERE ON REAR REPLACE FRT TIRES
Dealer Reported01/04/2012Metro Lexus852400416966TECH PERFORMED DIGITAL TEST AND BATTERY FAILED,REPLACED ENGINE BATTERY UPON INSPECTION BATTERY FAILED DIGITAL TEST
Dealer Reported03/22/2011Metro Lexus791030397151CHANGE ENGINE OIL AND FILTER, CHECK/ADJUST ALL FLUID LEVELS, CHECK/ADJUST TIRE P CHANGE ENGINE OIL AND FILTER, CHECK/ADJUST ALL FLUID LEVELS, CHECK/ADJUST TIRE PRESSURE
Dealer Reported03/22/2011Metro Lexus791030397151ROTATE TIRESCHECK TREAD AND CONDITION - SET TIRE PRESSURES - ROTATE TIRES - CHECK TREAD AND CONDITION - SET TIRE PRESSURES
Dealer Reported03/22/2011Metro Lexus791030397151METRO LEXUS COURTESY INSPECTION
Dealer Reported10/14/2010Metro Lexus755450385762REPLACE (AIR PURIFICATION) INCABIN A/C FILTER - REPLACE (AIR PURIFICATION) IN - CABIN A/C FILTER
Dealer Reported10/14/2010Metro Lexus755450385762TECH REPLACED THE EVAPORATOR CASE SEAL THAT WAS LEAKING CUSTOMER STATES THERE IS WATER DRIPPING UNDER THE PASS SIDE OF THE DASH. CUSTOMER STATES IT TAKES ABOUT 10MIN. NOTE; CUSTOMER DOES HAVE LEXUS EXTENDED WARRANTY REF PLAN EXPIRATION MILEAGE VSA PLATINUM 0009436483 YH7 APPROVED AND ISSUED 03/01/2004 03/01/20 - 75466 FOR REPAIRS PERFORMED ON LINES ""A"" & ""C"";.......... - REF AUTHORIZATION # VSA 10I9348 PER MIKE @ LEXUS EXTENDED WARRANTY 10/12/10, CLAIM TOTAL = $1,105.48.......... $449.40 LABOR - ($64.20 LABOR, OP CODE 170181 PAYS .6HR FOR EXHAUST REPAIR, $385
Dealer Reported10/14/2010Metro Lexus755450385762TECH REPLACED CENTER MUFFLER ASSEMBLY WITH GASKETS AND CLAMPS EXHAUST NOISE NOTE; UPON TEST DRIVE, TECH REPORTS FOUND EXHAUST LEAKING/NOISY, FOUND CENTER MUFFLER LEAKING. NOTE; CUSTOMER DOES HAVE LEXUS EXTENDED WARRANTY REF EXPIRATION MILEAGE VSA PLATINUM 0009436483 YH7 APPROVED AND ISSUED 03/01/2004 03/01/2011 1000 - 75466 FOR REPAIRS PERFORMED ON LINES ""A"" & ""C"";.......... - REF AUTHORIZATION # VSA 10I9348 PER MIKE @ LEXUS EXTENDED WARRANTY 10/12/10, CLAIM TOTAL = $1,105.48.......... $449.40 LABOR - ($64.20 LABOR, OP CODE 170181 PAYS .6HR FOR EXHAUST REPAIR, $385
Dealer Reported10/05/2010Metro Lexus754120385445TECH COULD NOT VERIFY CUSTOMER'S CONCERN,NOTICED AFTERMARKET WINDSHIELD INSTALLE CUSTOMER STATES THERE IS WATER DRIPPING FROM DASH ON THE PASSENGER SIDE. PLEASE ADVISE
Dealer Reported10/05/2010Metro Lexus754120385445ALF INSTALL STEERING FITTING KIT & SUPPORT KIT L - CUSTOMER STATES: ALF SSC******VERIFIED THRU DEALER DAILY 9/21/10 12/09/05 METRO LEXUS (63408) ALF - SAFETY RECALL ALF - CERTAIN 2003 THROUGH 2007 MODEL YEAR LEXUS LX 470 VEHICLES STEERING SHAFT ************** - MT
Dealer Reported09/21/2010Metro Lexus737460384771TECH INSTALLED 2 NEW TIRES ON FRONT, ROTATED TIRES THAT WERE ON FRONT TO REAR PE CUSTOMER STATES: CLIENT WAS RECOMMENDED AT LAST SERVICE TO REPLACE TWO OF THE TIRES. CLIENT WOULD LIKE THIS REPAIR DONE AT THIS TIME. PLEASE CHECK AND ADVISE.
Dealer Reported09/21/2010Metro Lexus737460384771CUSTOMER TO RESCHEDULE TO PERFORM SERVICE CAMPAIGN AT ANOTHER TIME ALF LX 470 STEERING KIT INSTALL IF TIME
Dealer Reported09/21/2010Metro Lexus737460384771PERFORM 4 WHEEL ALIGNMENT ADJUST TO FACTORY SPECIFICATIONS - PERFORM 4 WHEEL ALIGNMENT - ADJUST TO FACTORY SPECIFICATIONS
Dealer Reported09/21/2010Metro Lexus737460384771PHONE INFO CALL 440 - 218 - 9148
Dealer Reported09/20/2010Metro Lexus73770038464970,000 MILES OR - 62 MONTH MAINTENANCE SERVICE - 70,000 MILES - OR - 62 MONTH MAINTENANCE SERVICE - 73668 BRAKES: FRONT @ 6MM AND REAR @ 11MM RECOMMEND REPLACEMENT @ 3MM PAD THICKNESS...TIRES: FRONT @ 6/32 AND REAR @ 7/32 RECOMMEND REPLACEMENT @ 3/32 TREAD DEPTH. CHANGE ENGINE OIL & FILTER ROTATE TIRES CHECK AND CORRECT TIRE PRESSURE INSPECT AIR FILTER
Dealer Reported09/20/2010Metro Lexus737700384649METRO LEXUS COURTESY INSPECTION
Dealer Reported09/20/2010Metro Lexus737700384649REPLACE 2 FRONT WIPER INSERTS
Dealer Reported03/25/2010Metro Lexus68811037125865,000 MILES OR - 58 MONTH MAINTENANCE SERVICE - 65,000 MILES - OR - 58 MONTH MAINTENANCE SERVICE - 1 FRONT TIRE TREAD AT 7/32 REAR AT 7/32 RECOMMENDED REPLACEMENT AT 3/32 FRONT BRAKE PADS AT 7MM REAR AT 7MM RECOMMENDED REPLACEMENT AT 3MM CHANGE ENGINE OIL & FILTER ROTATE TIRES CHECK AND CORRECT TIRE PRESSURE INSPECT AIR FILTER INSPECT BRAKES INSPECT DR
Dealer Reported03/25/2010Metro Lexus688110371258METRO LEXUS COURTESY INSPECTION
Dealer Reported03/25/2010Metro Lexus688110371258THE TECH REPLACED FUEL FILTER FUEL FILTER NOTE; DUE TO AGE & MILEAGE OF VEHICLE, TECH RECOMMENDS CHANGE FUEL FILTER ASSY AS PREVENTIVE MAINTENANCE MEASURE.
Dealer Reported03/25/2010Metro Lexus688110371258PERFORMED INSPECTION AND FOUND WINDSHIELD WILL NEED REPLACED CUSTOMER TO RESCHED CUSTOMER STATES: CRACK ON FRONT WINDSHIELD ON PASSENGER SIDE. PLEASE CHECK AND ADVISE TO CUSTOMER'S INSURANCE CO; STATE FARM - 440 - 602 - 7600, AGENT LARRY LANE, REF POLICY NUMBER 486495 - B12 - 35F. - 1 NOTES; CUSTOMER OR METRO LEXUS HAS NOT YET BEEN IN TOUCH WITH INSURANCE CO FOR APPROVAL, NOT SURE IF INSURANCE WILL ALLOW FACTORY GLASS OR WILL REQUEST AFTERMARKET WINDSHIELD ASSY. - AFTERMARKET WINDSHIELD IN VEHICLE AT THIS TIME. - CUSTOMER ADVISES NEE
Dealer Reported03/25/2010Metro Lexus688110371258OK RETURN INFO; PLEASE MAKE SURE CAR RETURNED BY END OF DAY THURSDAY 3/25/10 SURE, CUSTOMER LEAVING ON TRIP FRIDAY. THANK YOU
Dealer Reported03/25/2010Metro Lexus688110371258OK CONTACT 440 - 218 - 9148 OR 440 - 570 - 8018
Dealer Reported09/11/2009Metro Lexus63476035711860,000 MILES OR - 54 MONTH MAINTENANCE SERVICE - 60,000 MILES - OR - 54 MONTH MAINTENANCE SERVICE - 1 BRAKES: FRONT @ 8MM AND REAR @ 11MM RECOMMEND REPLACEMENT @ 3MM PAD THICKNESS...TIRES: FRONT @ 9/32 AND REAR @ 8/32 RECOMMEND REPLACEMENT @ 3/32 TREAD DEPTH. REPLACE ENGINE OIL AND FILTER REPLACE ENGINE AIR FILTER ROTATE AND COMPUTER BALANCE TIRES VISUA
Dealer Reported09/11/2009Metro Lexus634760357118VEHICLE(BLK,LX470,GX470) COMPLETE EXTERIOR/INTERIOR DETAIL******** BILLING NOTE - VEHICLE(BLK,LX470,GX470) COMPLETE EXTERIOR/INTERIOR DETAIL******** - BILLING NOTE; CUSTOMER ADVISES WILL SEND COUPON IN WITH CAR FOR $30.00 DISCOUNT OFF OF STANDARD $239.95 PLUS TAX DETAIL PRICE, THANK YOU
Dealer Reported09/11/2009Metro Lexus634760357118$30.00 OFF COUPON HAS BEEN APPLIED VEHICLE(BLK,LX470,GX470) COMPLETE EXTERIOR/INTERIOR DETAIL******** - BILLING NOTE; CUSTOMER ADVISES WILL SEND COUPON IN WITH CAR FOR $30.00 DISCOUNT OFF OF STANDARD $239.95 PLUS TAX DETAIL PRICE, THANK YOU
Dealer Reported06/12/2009Metro Lexus602450350249REPLACE REAR BRAKE PADS, SHIMS, HARDWARE KIT, LEFT REAR ROTOR & MACHINED THE RIG CUSTOMER STATES: WHEN BRAKING THERE IS A SCREACHING NOIS E COMING FROM THE REAR OF THE VEHICLE. STATES WEATHER DOES NOT INFLUENCE THE SOUND. PLEASE CHECK AND ADVI SE.
Dealer Reported06/12/2009Metro Lexus602450350249THE LASTEST NAVIGATION UPGRADE IS $319.50+TAX, CUSTOMER DECLINED @ THIS TIME. CUSTOMER STATES: WHEN ENTERING HOME NUMBER ON THE GPS IT DOES NOT GIVE ACCURATE DIRECTIONS TO THE HOME. IT SAYS THE TELEPHONE NUMBER IS NOT VALID AND DOES NOT PROVIDE DIRECTIONS. PLEASE CHECK AND ADVISE.
Dealer Reported04/28/2009Metro Lexus591500346442REPLACED AC LINE AND EVAC AND RECHARGED SYSTEM CUSTOMER STATES: THE AC IS NOT BLOWING COLD AIR - 1 LEXUS EXTENDED CONTRACT AUTH#VSA1SJ5973 CLAIM TOTAL $466.42
Dealer Reported02/10/2009Metro Lexus580560341098CHANGE ENGINE OIL AND FILTER, CHECK/ADJUST ALL FLUID LEVELS, CHECK/ADJUST TIRE P CHANGE ENGINE OIL AND FILTER, CHECK/ADJUST ALL FLUID LEVELS, CHECK/ADJUST TIRE PRESSURE
Dealer Reported02/10/2009Metro Lexus580560341098CUSTOMER STATES: THE DRIVERS FRONT TIRE IS LOOSING AIR. PLEASE CHECK AND ADVISE. CUSTOMER STATES: THE DRIVERS FRONT TIRE IS LOOSING AIR. PLEASE CHECK AND ADVISE. $26.99 TAX - 58055 TECH INSPECTED AND FOUND A NAIL IN THE LEFT FRONT TIRE. TECH REPAIRED
Dealer Reported02/10/2009Metro Lexus580560341098VALET PICK UP AND DELIVERY
Dealer Reported07/11/2008Metro Lexus536000323989TECH REPLACED THE REAR HEIGHT SENSOR CUSTOMER STATES: THE REAR OF THE TRUCK SEEMS TO BE STUCK IN LOW POSITION,RIDES VERY ROUGH IS BOUNCY HAS BEEN GOING ON FOR ABOUT A WEEK NOW CK ADVISE - C - VEHICLE RIDING ROUGH/BOUNCY C - REAR HEIGHT SENSOR SEIZED R - REPLACED RR HEIGHT SENSOR **GOODWILL - CUSTOMER SATISFACTION** - 53600 LEXUS EXTENDED WARRANTY AUTHORIZATION #VSA10Y7680, PARTS $355.10, LABOR $63.00, RENTAL $45.00, TOTAL $463.10
Dealer Reported04/11/2008Metro Lexus525440316063CHANGE ENGINE OIL AND FILTER, CHECK/ADJUST ALL FLUID LEVELS, CHECK/ADJUST TIRE P CHANGE ENGINE OIL AND FILTER, CHECK/ADJUST ALL FLUID LEVELS, CHECK/ADJUST TIRE PRESSURE
Dealer Reported04/11/2008Metro Lexus525440316063CUT AND PROGRAMMED NEW MASTER KEY CUST STATES THAT THE MASTER KEY CASING CAME APART OK TO REPLACE
Dealer Reported04/11/2008Metro Lexus525440316063ROTATE TIRES - 1 BRAKES @ 9MM FRT 4MM REAR RECOMMENDED REPLACEMENT ON BRAKES @ 3MM TIRES @ 10/32 FRT AND REAR RECOMMENDED REPLACEMENT ON TIRES @ 3/32
Dealer Reported08/17/2007Metro Lexus474740295433CHANGE ENGINE OIL AND FILTER, CHECK/ADJUST ALL FLUID LEVELS, CHECK/ADJUST TIRE P CHANGE ENGINE OIL AND FILTER, CHECK/ADJUST ALL FLUID LEVELS, CHECK/ADJUST TIRE PRESSURE
Dealer Reported06/18/2007Metro Lexus4606702896594 TIRE CHANGE(MOUNT AND BALANCE) CUSTOMER STATES CAR NEEDS TIRES
Dealer Reported06/18/2007Metro Lexus460670289659PERFORMD POWER STEERING FLUSH PERFORM POWER STEERING FLUSH
Dealer Reported02/28/2007Metro Lexus424370278537VEHICLE(BLK,LX470,GX470) COMPLETE EXTERIOR/INTERIOR DETAIL PAINT SEAL/FABRIC GUARD - 42437 CAR IN ROUGH CONDITION - NOT PERFORMING XZILON - PERFORMED DETAIL INSTEAD - REFUND CUST DIFFERENCE OF COST OF XZILON (595) AND DETAIL - REFUND APPROX 290.30
Dealer Reported01/31/2007Metro Lexus42303027806835,000 MILES OR - 34 MONTH MAINTENANCE SERVICE - 35,000 MILES - OR - 34 MONTH MAINTENANCE SERVICE - 1 FRT BRAKES ARE NEW REAR BRAKES ARE AT 4.0MM TIRES ARE AT 7/32 RECOMMEND REPLACEMENT AT 3/32 CHANGE ENGINE OIL AND FILTER ROTATE TIRES AND ADJUST TIRES TO CORRECT TIRE PRESSURES INSPECT AIR FILTER INSPECT FRT AND REAR BRAKES INSPECT DRIVE SHAFT BOLTS AND
Dealer Reported01/31/2007Metro Lexus423030278068REPLACE 2 FRONT WIPER INSERTS
Dealer Reported01/31/2007Metro Lexus423030278068REPLACE 1 REAR WIPER INSERT
Dealer Reported01/31/2007Metro Lexus423030278068REPLACED FRT BRAKE PADS RESURFACED FRT DISC ROTORS AND REPACKED BEARINGS REPLACE FRT BRAKE PADS AND RESURFACED ROTORS AND REPACKED BEARINGS
Dealer Reported01/31/2007Metro Lexus423030278068GUARDIAN GLASS REPLACED GLASS BILLED GUESTS INSURANCE COMPANY CUSTOMER STATES GLASS IS CRACKED
Dealer Reported01/31/2007Metro Lexus423030278068REPAIRED PASS DOOR DENT REMOVED DENTS FROM PASS SIDE DOOR
Dealer Reported09/11/2006Metro Lexus37551026586230,000 MILES OR - 24 MONTH MAINTENANCE SERVICE - 30,000 MILES - OR - 24 MONTH MAINTENANCE SERVICE - FRT BRAKES AT 5.5MM REAR BRAKES AT 6.0MM RECOMM END REPLACMENT AT 3.0MM TIRES ARE AT 7/32 RECOM MEND REPLACEMENT AT 3/32 REPLACE ENGINE OIL AND FILTER ROTATE TIRES VISUALLY INSPECT FRT AND REAR BRAKES INSPECT THE FOLLOWING ITEMS TIRE WEAR AND ADJUST PRESS
Dealer Reported09/11/2006Metro Lexus375510265862INFO APPT MADE BY CARLYN
Dealer Reported04/11/2006Metro Lexus316290253012CHANGE ENGINE OIL AND FILTER,CHECK/ADJUST ALL FLUID LEVELS,CHECK/ADJUST TIRE PRE CHANGE ENGINE OIL AND FILTER,CHECK/ADJUST ALL FLUID LEVELS,CHECK/ADJUST TIRE PRESSURES
Dealer Reported03/03/2006Metro Lexus292320249912R.HT CNTRL SNSR SUBASSY,1SD - CUSTOMER STATES HEIGHT CONTROL INOP/CAR BOUNCING EXCESSIVELY - C - REAR OF VEHICLE TO HIGH C - REAR HEIGHT SENSOR SHORTED INTERNALLY CRR - R&R REAR HEIGHT SENSOR
Dealer Reported12/09/2005Metro Lexus25810024319010,000 MILES OR - 8 MONTH MAINTENANCE SERVICE - 25,000 MILES - OR - 8 MONTH MAINTENANCE SERVICE - BRAKES @ 6.5MM FRT 7MM REAR RECOMMENDED REPLACEMENT ON BRAKES @ 3MM TIRES @ 9/32 FRT 8/32 REAR RECOMMENDED REPLACEMENT ON TIRES @ 3/32 CHANGE ENGINE OIL & FILTER ROTATE TIRES CHECK AND CORRECT TIRE PRESSURE INSPECT AIR FILTER INSPECT BRAKES INSPECT DRIVE
Dealer Reported12/09/2005Metro Lexus2581002431905LB INSTALL DRL KIT MY0305 LX470 (SSC) - 5LB LX470 DRL KIT - F
Dealer Reported06/20/2005Metro Lexus208160228007CHANGE ENGINE OIL AND FILTER CHECK ALL FLUID LEVELS
Dealer Reported06/20/2005Metro Lexus208160228007**INFO***** COLLECT CHECK OR C/C FOR TOTAL FROM CUST
Dealer Reported04/05/2005Metro Lexus171530221084TECH INSPECTED AND FOUND NAVIGATION SYSTEM TO BE WORKING AS DESIGNED CUST STATES NAVIGATION IS SENDING CUSTOMER IN WRONG DIRECTION
Dealer Reported04/05/2005Metro Lexus171530221084INFO REPLACED NAV DISC IN FEB.
Dealer Reported02/25/2005Metro Lexus15281021813715,000 MILES OR 1 YEAR SERVICE - TIRES 9/32"" ALL AROUND BRAKES 8.5MM FRONT 9MM REAR CHANGE ENGINE OIL & FILTER ROTATE & COMPUTER BALANCE TIRES CLEAN AND LUBE BRAKES REPLACE WIPER INSERTS INSPECT AIR FILTER CHECK & CORRECT TIRE PRESSURE INSPECT STEERING LINKAGE INSPECT DRIVE SHAFT FLANGE
Dealer Reported02/25/2005Metro Lexus152810218137HEIGHT SENSORS '04 LX430 CUST STATES THAT THE HEIGHT CONTROL IS OFF/FRONT IS HIGHER THAN THE REAR CK ADVISE - CHECK FOR UNEVEN RIDE HEIGHT FOUND REAR RIDE HEIGHT SENSOR INOP R&R SENSOR PER TSB SO002 - 04
Dealer Reported02/25/2005Metro Lexus1528102181374LG REPLACE DVD ALL OTHER (SSC) - 4LG REPLACE DVD - SC
Dealer Reported12/16/2004Metro Lexus10962021237410,000 MILES OR 8 MONTH SERVICE - BRAKES @ 9MM FRT 9MM REAR TIRES @ 9/32 FRT 9/32 REAR CHANGE ENGINE OIL & FILTER ROTATE TIRES CHECK AND CORRECT TIRE PRESSURE INSPECT AIR FILTER INSPECT BRAKES INSPECT DRIVE SHAFT BOLTS & CLAMPS RE - TORQUE FLANGE BOLTS INSPECT STEERING LINKAGE INSPECT BODY
Dealer Reported12/16/2004Metro Lexus109620212374OTHERS R&R* CUST STATES THAT THE REAR HEIGHT SENSOR/CONTROL SEEMS OFF CK ADVISE - CAR BOUNCING ON ROAD DEFECTIVE HEIGHT CONTROL SENSORS R&R BOTH FRONT/REAR HEIGHT CONTROL SENSORS
Dealer Reported07/23/2004505802003555,000 MILE SERVICE CHANGE ENGINE OIL AND FILTER CHECK ALL FLUID LEVELS - F
Dealer Reported03/03/2004100188681PREDELIVERY SERVICE FOR USA ALL ALTITUDES - PRE - DELIVERY SERVICE FOR USA ALL ALTITUDES - F
Dealer Reported03/03/2004100188681NEW CAR DETAIL
Congrats on your purchase!
You might want to clean up what you pasted, as that's a lot of blah for us to sift through. I assume it's an '04? How many miles?
I agree, if you want input, clean up the list, it's mostly irrelevant.
Ask about service over the last 2 years, since the Lexus records end in '13
Look at the FAQs on this forum for ideas on what you might want to address immediately after purchase.
I'm so sorry about that. I posted it and didn't look again until I saw the replies. Something got seriously messed up when I pasted the service history in here.
Current mileage is at 101k
Here is a link to a google doc with everything I have. For the more indepth repairs I left the original text from the records as to not miss anything. I'm not sure what happened between 12/13 and 6/15 but am snooping around trying to figure it out.
https://docs.google.com/spreadsheets/d/14nWlCZnLWyf2ZuGiALosbVkCHWg8S9gN3Nmzdqs5liA/edit?usp=sharing
