For Sale "Caddy on Dubs"FJ40 buggy built by Randy Slawson
2004 Corvette LS1 engine, Turn Key engine harness, custom tune tune by Jim's Performance
LS1 manifold reversed with K&N intake/filter in cab
Custom headers
Switchable dual high output electric fuel pumps with adjustable pressure regulator
16 gallon fuel cell
Remote tranny and oil coolers
4L60e transmission with Art Carr shifter
Atlas II transfer case
Full HDMW skid plates under belly and rockers
Front and rear Spidertrax 9" steering axles with PortalTek (now owned by Torq Motorsports) GenIII portal boxes (3.50:1 differential gears and 2.08:1 portal gears = 7.28:1 final gear ratio)
Strange Engineering high pinion/big bearing 3rd members
Front and rear ARB lockers
Cutting brakes
Wilwood dual master cylinders/brakes
Solid Industries Hubs/rotors
Currie Anti-Rock swaybars
PCS ultra4 full hydo setup front/rear
RCV 300M axleshafts and portal stubshafts
King 2.5 x 14" coilovers
King air bump stops
5-point Hooker Harnesses
Mastercraft 3G seats
Safety nets
Odyssey battery with electrical masterkill switch
PCI Race Radios Comlink6 communications system
PCI RaceAir dual fresh air pumper setup
Brand New Lowrance HDS5 Gen2 GPS with Point1-Baja external antenna
Warn 9.5ti winch / synthetic rope
Dual Hella horns
Toyota FJ40 grille
(2)LED light bars
(5)Brand New...never run 39" BFG red label Krawlers to be put on
(5)Brand New...never run Trailready alluminum beadlock wheels to be put on
Full set of skins as seen in photos (minus the Team Sure Click decals) with dzus fasteners
Aluminum and plexiglass driver/passenger firewall panels
Removable rear spare tire carrier and rear cargo rack
109" wheelbase
83" track
Spare RCV axleshafts, spindles, PSC pump mounted in vehicle, Alternator mounted in vehicle, miscellaneous ARB parts, miscellaneous bearings/seals, etc...
Please feel free to call or text me @ 413-262-1217 . Will help arrange delivery, pickup, or even meet within a reasonable distance. Located in Beverly,Massachusetts 01915. $45,000. Very Motivated Seller!!! Also open to trades for 3-4 seat buggies. Willing to make a deal without parts like GPS, Communications, LED bars, winch,etc...Make an offer!!
Here's some older photos from a previous owner:
