Bump stop spacing
australia
Can someone help me out with this, the rear shocks i want to use are 410mm compressed length, with standard bump stops you would space them down 45mm (2 inches) to account for the length, but im running timbren rears stops, the metal bracket is 35mm tall giving me a safe compressed length of 400mm but the rubber aeon spring is 95mm. My problem is im not sure if i can get away using the rubber spring as the extra 10mm i need or not because the rubber is designed to compress by quite a bit.
Do i simply need a 10mm solid spacer or is the timbren on its own enough?
