For Sale Built 85 Toyota 4runner, 1 ton, v8, doubler, 40s 1st gen
85 white runner
Complete rig has 12 total days of wheeling and less then 200 road miles (only the body, motor and tires have little more time)
350 small block chevy,
approx 6,000 mile motor, full rebuild, mild cam, etc...
Transmission sm465
Professionally done Fully rebuilt, with full bearing and seal kit,
Doubler
Fully rebuilt, with full bearing and seal kit, WMS 203-205 doubler with WMS clocked adapter, (205 is clocked FLAT), fully custom made shifters triple stick
New longer front lift springs,
rear springs are AOR rolling eyes (johnny joints in the springs) originals, with a traction bar on them at all time so they are not bent up.
Rear traction bar, custom 3 point setup adjustable for pinion change, setup a slip shaft due to very tight space. dual bar 3/4 wrap around driveshaft to protect from rock damage
D60F 5.13 detroit full width, fully rebuilt, bearing and seal kit, new detroit, later full diameter axle shafts, new 35 spline outers, New 35 spline warn lockouts, new axle u joints. SKY manufacturing hysteer arms
14b 5.13 detroit full width, new discs, new calipers and pads, 1410 rear joint with 1350 cv at tcase
AXLES were done by Inland Truck Parts
Custom front cage, 1.5 .120, main hoop is .134, fits tall driver and passenger, hugs interior ceiling and pillars, grab bars, rear hoop just outside the lip for the hardtop, easy to finish for a full family cage, allows for full use of a factory hardtop. Tube doors
All pro rock sliders
40" goodyear mtrs Approx 90-95% 17s alum 4.5 bs so the rig measures 82" to fit on a normal car trailer, will squeeze on a 81" etc...
Belly nearly flat 1.5" stick down for the crossmember/tcase
106" wheelbase, 26" belly height on pretty fresh springs in front will settle,
$15K OBO or trade
Trade for, 03-05 cummins quadcab shortbox 4x4, (complete or project motorhome/rv, Toter, garage hauler) Semi tractor w or without trailer
Will ship, out of basically omaha,ne
click here for build pics
click here for Pics from Moab
click here for pics from crawling other places
x
