For Sale Built 80 series Bay area ca
SOLD!!!!!!
Up for sale is my 1991 land cruiser. It has the reliable 3fe engine and A440 transmission, runs good and has clean paint and cloth interior.
A/c and heater work good,tinted windows, pioneer cd stereo. Battery replaced 3months ago. Wires, cap/rotor, plugs and air filter replaced last year along with front rotors,pads,master cylinder and rebuilt calipers. It does throw a egr code but runs fine. Probably just need to be cleaned.
I love this cruiser but it must go.
Suspension:
- Slee rear extended sway bar brackets
- REF front swaybar brackets
- MAF 30mm poly front spring spacer
- Slee Caster Plate Kit (Welded)
- Old Man Emu Front N73L shocks (extended travel)
- Old Man Emu Rear N74L shocks (extended travel)
- Old Man Emu Front 850J springs
- Old Man Emu Rear 863 springs
Brakes:
- Slee Frame to Axle SS braided brake lines
- Slee Axle to Caliper SS braided brake lines (not installed)
- New Master Cylinder
- New Front Rotors & Pads (OEM)
-Reman. Front Calipers
Drivetrain:
- Aussie Locker in rear axle (Locking Differential) www.aussielocker.com
- Front axle service performed January of this year with full knuckle rebuild kit (differential, axle seals, wipers, bearings, etc.) www.cruiseroutfitters.com
-New Birfs and longer OEM spline drives just installed - Center diff lock switch
Tires/Wheels:
- 315/75/16 75% tread (35" equivalent) BFG Mud Terrians on OEM Toyota Landcruiser wheels
Custom front plate bumper
New parts not installed.
-Starter plunger and brush kit (oem)
Has a little over 225k miles but don't worry about mileage... its a 3fe landcruiser and is known to go well over 350k. Also included is the factory service manuals and a full size (35'') spare
More pics
So it only has a rear locker?
you need to post a price and location in your first post.. fyi
Fixed.
Rear aussie locker(works great) center diff lock works in hi or lo 4wd and the front is open.
This set up will get you through most trails with ease.
I'm right around the corner from you BTW. (redwood city)
Do u still have 4.11's, or did u change axle gears? Bump.
