For Sale Built 08 FJC, ATLAS, SAS, URD, 1 Tons
08 FJ Cruiser, SAS, Atlas, Tons, etc etc
WHY: To pay for upcoming KOH and 2012 Race season
WHAT:
2008 Toyota FJ Cruiser “Trail Teams Edition”- Dana 70/60 Axles, Supercharged, Atlas, Linked and Locked on 40's
* The best built streetable FJC on the planet
________________________________________
All 08 FJ Trail Teams options, black-out exterior items (mirrors/handles) Trail teams badges, Warm white exterior, white/black trim interior, power everything, remote central locking, alarm, in dash 6 stack CD player, COLD air conditioning, HOT heat, guage package, 5 seats, Inverter, Leather steering wheel, Atlas billet shift knobs etc. But the stuff you really want to know...
DRIVETRAIN:
Engine : Toyota V6 1GR-FE
Transmission : Toyota A750F 5speed Automatic with huge oil cooler
Forced Induction : URD Supercharger Kit with 80mm pulley, Under hood Water 2 Air intercooler, Supercharger front mount radiator and oil cooler.
Fuelling: URD 7th Injector Kit, URD 255LPH Walbro Fuel pump kit (remote filter)
Exhaust : Doug Thorley Headers, Stock Precats, Rear Cat delete, Custom routed hi-clearance exhaust 2.5in, Magnaflow muffler, hi-clearance tail pipe
Batteries: Painless performance dual battery setup, Optima RED main and Optima YELLOW secondary battery.
OBA - ARB mini Air Compressor
AXLES- Front 35spl Dana 60, ARB, Warn Supreme locking hubs REAR, FF Dana 70, ARB (5:86 R&P)
ATLAS Transfer case and A/A e brake off T-case
STEERING:
Links : Borgeson
Gear: Howe IFS steering box valved, tapped
Ram: Howe 2" x 8" hydro-assist ram
Pump: Howe Performance TC pump 1450 PSI
Reservoir: Howe high capacity reservoir with filter
Steering: Toyota IFS steering box tapped for hydro assist, Howe Hydro Assist, Ballistic Fabrication 7/8 QA1 Heim Steering Kit 1.5x.250DOM, ThurenFab 1.5x.250DOM 7/8 QA1 Heim tie-rod.
Brakes: Stock 3500, All new rotors, pads, remanufactured calipers, new stainless steel hoses.
Other: New balljoints, B&M super synthetic oil. Rockcrusher differential cover, lubelocker gasket, WFO 1350 Yoke
SUSPENSION:
Front
Type: 3-link with panhard
Coilovers: Walker Evans 2.0" x 14" travel externally adjustable remote reservoir coilovers
Springs: Eibach 12" 300# over 14" 450#
Joints: Currie Johnny Joints on lower links / Heim joints on panhard / Heims on upper link
Bump stops: Fox 4" travel 2.0 air bumps (Set to 2.5in travel)
Shock mounts - Ballistic Fabrication coilover towers
Brackets: Ballictic Fabrication
Frame plates: 3/16 Frame Plating (front frame rails inner and outer, scab plates at upper link mounts)
Limit Straps : Beard 23in
REAR
Coils: OME420 Landcruiser Competition Coils
Shocks: KING 2.0 x 10" travel remote reservoir shocks (Custom built for this truck)
Swaybar: Rock Equipment 'Rock Crawler' Swaybar (aluminum arms)
Limit Straps: Bears 13in
Body Lift : 4Crawler 1.25in
Transfer case
Tcase: Atlas 5.0
Adapter: Advance Adaptors FJ Cruiser Adaptor
Fr Output shaft: 32spl 1350 with Driveline Specialties Deep throat yoke
Rr Output shaft: 32spl 1350 CV Style
Shifters : Twin cable shifters w/Billet knobs
Crawl ratio: 205:1
Speed sensor: GM VSS wired to Digital Dakota Speedo Calibration Unit.
Other: Advance Adaptors rear output disc brake parking brake setup
Driveshafts:
Coast Driveline rear CV 1350
Coast Driveline front 1350
ARMOR
Front Bumper: Man-A-Fre "OzBogan" Front winch bumper
Rear Bumper: Man-A-Fre Kaymar Swingout with tire carrier modified to fit 40in tire, and swingout with ladder/quart crate.
Sliders: Man-A-Fre Wide
Skid plates: Budbuilt gas tank skid
Belly pan: Flat belly cross member Laser cut
Flares: Bushwacker Pocket Style Fender Flares
Tires / Wheels
Tires: 5x 40x13.5R17 Goodyear 'old style' MTR Rears 70 - 80% front 90%
Spare 20% 3 more ranging from 10 - 20%
Wheels: 17x9 TRAIL READY Aluminum
ELECTRICAL:
Horns : Hella
Auxillary fuse boxes : primary battery - under hood
: secondary battery - under hood and under dash
Inverter : Stock rear 400w.
: Secondary under seat 400w
GPS : Lowrance XOG Gps with topo and trail map capability
: Microsoft GPS antanna for Streets/Trips 09 for laptop
CB : Uniden 40ch CB radio/ Firestick cable/antanna
:Secondary hand held on bar.
FRS : Cobra FRS pr
Cameras : Front and rear cameras hooked up to toggle switch and screen mounted above center console on cage.
Interior Lighting : 30LED pods in both roof lights.
: Hella Adjustable Red roof light
Instruments : Scanguage 2 xguage
: Stealth boost guage install
12v power outlets : one extra in center console, two in rear. Also has 12v direct power for ARB (etc) refrigerator in rear.
All Fog/Spot lights / Lockers operated by factory toyota labelled switches in the center console.
LIGHTING:
2x Hella 4000's on the front bar.
4x Hella 500s on roof Defender light Rack
2x Hella 550 Fogs on side of roof rack
Front 4in fog lights on bumper.
Hella Worklight on Kaymar rear bar (hooked to reverse and a seperate switch for camping)
Hella Headlight Upgrade bulbs
Vision X Tantrum LED Remote Rock Lights (8)
Aeroflow HLC Covers
underhood LED bar
OTHER/MISC
ARB Safari Snorkle
Man-A-Fre Long Range Auxillary 19gal extra fuel tank (increased fuel capacity to 38gallons), hooked up for car-to-car transfer to help your buddies out!
Stock roof rack, defender roof light bar, hi-lift mounts, extra crossbars, roof storage bag.
Mag Lights front and rear, Fire extinguisher in the rear.
Wheelbase: 107"
Frame Height: 24.5"
Width : 85in
Height (roof) : 85in (not inc rack)
Cold A/C, Hot heat, All Airbags functional, no warning lights on dash, Cruise control works, Speedo is accurate. Mileage as of 02/14 is 36xxx.
returns approx 11MPG if driven sensibly (ie boost under 2PSI) at 65 - 70MPH. gets a rnage of around 400 - 450mile combined both tanks, Tracks nice. Doesnt drive much different from a modified IFS vehicle but you do need to be aware while driving it.
CURRENTLY REGISTERED IN CALIFORNIA WITH THE SUPERCHARGER / EXHAUST MODS. Its currently smog exempt until 2013 but Im not sure if thats transferrable.
PRICE.... $32,000, May take sportscar, enclosed trailer,ATV as partial trade
LOCATION... El Paso Texas
As requested, I will post more picts of rear, interior etc later today
You're selling already!? Man, I wish I had the money for this rig. The price is more than reasonable with everything that Ben put on it. GLWS!
Just curious where the old railroad tunnel, GLWS!
Thanks for the interest. I just put brand new BFG KM2 37's and now drives great at 70MPH:)
Still fo sale. However, I have had some tempting offers. Still holding out for the right one. Make me an offer;)
I'm trying to push it on every "SAC" thread I see pop up.
I was actually thinking about yours and plnfxr's earlier this week, and I'm betting a two minute YouTube video would work wonders at marketing to more than just the FJC/LC crowd.
My two cents.
My two cents.
Appreciate the help/marketing. The "YouTube" idea is a pretty good idea. I may try that when I get time. Heck, the longer it takes to sell, the easier it is to justify keeping it because my wife is getting used to seeing it;)
I've had some interesting offers but no deals. Feel free to make an offer.
