Hey Guys Hoping you can give some input on our compressor experiments down here in Costa.
Built a unit using a Bitzer refer pump.
Near silent and has great cfm. at about 850 rpm with a 2hp 220 motor.
6 minutes to fill 200 liters.
I closed the oiler hole off with a plate but we were still getting oil in the air.
These pistons have only 2 pressure rings no oil ring.
I am wondering if I machine oil rings into the piston will this solve the oil issue?
I am hoping it will as they are great pump heads and the low db is nice.
Idea is to run 2 on the same tank and up our cfm for sand blasting.
I am guessing this will fix it but need to ask before I waist time and $ to find out it is not the problem and refer pumps are NFG. for air compressors.
any info and input would be great.
We have one of those 110lb preasure tanks for blasting and need as much cfm as we can get.
Next ?
Right now the refer pumps are on moth balls till I get word on the oil issue.
I bought a big ass 2 phase pump off a neighbor.
We have it plumbed with 3/8 tube. Pump to tank.
The head exhaust manifold can take up to 1'' pipe.
If we open up the tubing will it make that much of a differance?
I know water and oil ya but compressed air?
As is this unit pumps up 200 liters in about 4 minutes.
I want to up this if I can.
Still short on cfm.
We are running 3/8 airlines and thinking if you say open it up then I should go 1/2 air lines.
We run 4 100 tanks linked for drying the air.
90% humidity here.
1st is wet, second better 3rd and 4th near nothing and then we have a series of filters along the line.
Great trick we found out by mistake for any of you needing dry air on the cheap.
Just have a secondary holding tank or tanks at the end of the line.
The air is much drier in the end seems to condense in the 1st and 2nd is much dryer.
We run these machines 5hrs a day and the last tanks haven't got much more than a rats piss in them when we are done the day and drain them.
The 1st pours water when we drain it. up to a quart +.
Anyhow hope one of you can answer these ?s on oil and opening up the air.
Pura Bira
Next ?
Still short on cfm.
90% humidity here.
Pura Bira
