building back up, what to do before trying to start
So Cal
just found the bolts I was needing. Looking for advice on what needs to be done before I try to start her up. Obviously an oil change, new spark plugs, but my main questions center around the rocker arms. I have fsm and will try to set it up accordingly, but what other helpful hints might you all have.
I'm not even sure what I should be searching under.
any help is always appreciated.
tjg
Torque down the rocker train bolts per spec., then set your preliminary valve lash.
Remember, you'll have to re-torque your head bolts again after a few cool down cycles. Same with the rocker bolts and then re-adjust the valve lash again.
NB. Re-torque the head bolts cold. Check valve lash hot. I'm sure you'll get more suggestions.
