- Joined
- Sep 17, 2003
- Threads
- 69
- Messages
- 4,591
- Location
- Sunnyvale, CA
- Website
- www.george4wd.taskled.com
^ Yep, a way to charge the aux while driving is pretty well mandatory, especially in warmer weather and/or with overcast days.
I've just returned from a near 6 week trip of which 3 1/2 weeks was in the oz bush with my older son visiting some remote areas. We had an ARB 50Q for food/drinks and also all other camp loads (lighting, water pump etc) run from the aux battery. Most of the trip was exploring and so only on a few days did we have a day lay over at a stop. It was essential for the aux to charge while we were driving around and no way would the solar have been able to top the battery up in just the morning/evening sun if the battery wasn't already topped off before we stopped. Additionally, it is winter in oz right now, with sunrise at around 7AM and sunset at about 5PM. So that gave maybe 3 hours from sunrise to when we would be moving again and maybe 1 hour from stopping to sunset.
With the vehicle alternator charging the aux while on the move, we would start each evening with a full charge, by morning we had used maybe 6 amp.hour. I found that in the cooler evening weather (temps 40F to 50F) the ARB was drawing 3A while running (variable speed/draw danfoss) and was running at most 1/8 of the time. So, 14 hours of non-solar for 3A at 1/8 the time means 14 x 3 x 1/8 = 5.25 amp.hour which is very impressive. Needless to say that a couple of hours of morning sun would have the aux battery back to full charge and the victron mppt controller transitioning to 'float' mode.
On a lay over day, the solar easily kept up with the fridge and camp loads, we had more solar than we could use. I would look for things to charge to not waste the solar
The victron with bluetooth was a nerd's delight. When bored at camp, I could connect to it (from the comfort of a camp chair near the fire) and check how many watts were being delivered, used and current battery voltage and charging status. One thing that I did find and have to rewire is that for the victron to measure amp draw from the load, the load's GROUND wire must be run from the load ground to the victron's LOAD ground terminal. The victron is measuring load current via the ground terminal sense. I originally had the load's positive terminal going to the victron positive load terminal, but the load's ground going to the body directly and this gave 0 Amp indicated on the victron app. Once I drew an additional dedicated ground wire from the load to the victron load ground the measurements came good.
I only run the fridge on the load output off the victron, this way I can keep an eye on fridge power usage versus solar delivery on stationary days. The fridge has an anderson SB50 on it (chopped off the original end) and plugs into a dedicated SB50 near it that then runs to the victron load +/- terminals.
cheers,
george.
cheers,
george.
