Buggy Use in NH
Sporin
Site Addict
Windsor, VT USA
Website
www.ukemafia.com
Some info for you non-street legal Buggy guys via the NEA...
Scott Hatch said:
So are "rock buggys" or non street registered 4x4s legal for use in NH?
While street registered 4x4s are a bit of a legal gray area when used off of public highways (private land), when a 4x4 is not registered for street use, it is then classified as an OHRV per RSA 215 A:1 Chapter VI
Per 215-A:21 Chapter II "no OHRV shall be operated in this state unless registered as provided in this chapter. No registration shall be required for an OHRV operated solely on land owned or leased by the owner of the OHRV."
Does my street registered 4x4 require an OHRV Sticker?
The registered part of the 215-A:21 Chapter II (above) is the gray area where street registered 4x4s are not required to obtain an OHRV sticker for use on Private Land.
What about traveling Class 6 Roads with my OHRV "buggy"?
Town selectman can authorize the use of OHRVs on town roads per RSA 215-A:6 Chapter IX. Pursuant to RSA 215-A:15. Per the above information a 4x4 non registered vehicle a.k.a. "buggy" is an OHRV.
Next you'll need to find towns that allow OHRVs on their town roads, and you'll need to know which type of roads are open to OHRVs (Class 4, 5, and/or 6). You will not be able to drive on "ATV" trails (Class 4, 5, or 6 highways open to OHRV use are not trails) with a buggy that is registered as an OHRV.
So how do I register my "Buggy" as an OHRV?
First you'll need to buy an OHRV sticker a.k.a. "ATV" sticker. The locations that sell these stickers are listed here:
N.H. OHRV Agents - N.H. Fish and Game
If this is the first time you are registering your 4x4 you will need some type of title or bill of sale. While most true "buggys" don't have anything left of the original body or the VIN plate, the engines do have a VIN and this can be used as the buggy's ID.
Every year after, you will be able to use the previous year's registration.
What about safety equipment?
NH does not require the use of seatblets for people 18 or over, however if you have a "buggy",you'd be foolish not to have and use these!
While the speeds obtained on true "buggy" trails wouldn't require eye protection, while operating at speeds legal on Class VI roads (defined below) eye protection is strongly advised. Per RSA 215-A:13-a any person under the age of 18 IS required to wear protective headgear and eye protection when operating (driving) an OHRV.
Lights are NOT required UNLESS you are out driving 30minutes before dawn or 30minutes after dusk you will need at least one head light and one tail light Per RSA RSA 215 A:1 Chapter I.
Good brakes are also required per RSA 215-A:14 Chapter I (2). This RSA required the braking system to stop an OHRV 40 feet at 20 miles per hour, or locking the tires to a standstill.
Per RSA 215-A:14 exhaust system are also required on all OHRVs. Open headers or no muffler can result in fines. More informaiton on sound levels per year of manufacture is listed here under RSA 215-A:12:
Section 215-A:12 Manufacturing Specification Requirements.
How fast can I travel on Class 6 roads that allow OHRV travel.
First and foremost, always travel a speed that is safe for the terrain you are driving. The speeds as defined per RSA 215-A:6 Chapter III for an OHRV are as follows:
RSA 215-A:6 Chapter III.
(a) No person shall operate an OHRV at a speed greater than is reasonable and prudent under the existing conditions and without regard for actual and potential hazards. In all cases speed shall be controlled so that the operator will be able to avoid colliding with any person, vehicle, or object.
(b) Where no hazards exist which would require a lower speed to comply with subparagraph (a), the speed of any OHRV in excess of the limit specified in this section shall be prima facie evidence that the speed is not reasonable or prudent and that it is unlawful:
(1) 10 miles per hour within 150 feet of any so-called bob-house, fishing shanty or occupied fishing hole of another.
(2) 10 miles per hour on class I through VI highways when the OHRV is being operated within the rights-of-way adjacent to such highways; town or city sidewalks; class IV, V, and VI highways approved for OHRV operation; and bridges open for OHRV operation.
(3) 10 miles per hour at trail junctions or parking lots, or when passing trail grooming equipment.
(4) 15 miles per hour on plowed roads on department of resources and economic development property open to OHRV operation.
(5) 35 miles per hour on all trail connectors.
(6) 45 miles per hour when operating an OHRV or snowmobile on any approved OHRV trail.
(c) The prima facie speed limits set forth in subparagraph (b) may be altered for a specific hazard.
(d) The driver of every OHRV shall, consistent with the requirements of subparagraph (a), drive at an appropriate reduced speed when approaching and crossing an intersection or railway grade crossing, when approaching and going around a curve, when approaching a hillcrest, when traveling upon any narrow or winding trail, and when a special hazard exists with respect to pedestrians or other traffic by reason of weather or trail conditions.
Discussion: nea4wd.org :: View topic - Buggy use in NH
