Buggy updates (1 Viewer)
So built a shroud and got a new 10" fan with a higher cfm rating
Mounted to radiator
Added a vacuum line from distributor to intake. Apparently it helps adjusts the timing when starting; tried a couple of times and engine seems to be turning easier.
Did a vacuum test as well. No fluctuation at higher rpms, still need to do a compression test to rule out some things
Posting for future reference
Ended up getting a P3 brake controller to replace the integrated one. It kept failing and got this error. The trailer is not even hooked up
