theferg
I'm not sure how to tell if your tranny mount is gone, but it sounds like your driver's motor mount is definitely gone. I had the same thing happening with the fan hitting the shroud on accerations on turns--turned out I had a broken driver's side mount. A month or two later, had the same thing happening and my gear shifter was hittin' it to the passenger side HARD when I would accelerate from dead stop (more so if I dropped the clutch hard). Driver's side mount was broken again. I also inspected the tranny mount and saw what looked to be a crack in the rubber. So I decided that since it was 20 years old anyway, it'd probably not be a bad idea to replace it even if it was not broken. Pulled it and it was indeed broken.
Good luck.
-Ferg-
Good luck.
-Ferg-
