Hey there all. I had a good buddy of mine suggest this site after I bought my 100 series. I get tons of good info from here, but now I'm in dire need of very specific information.
Specs: 1998 Toyota LC, 150K miles. NO Mods
We've had a nasty ice and snow storm up here in the northwest (Seattle area), and I put my truck in the "ditch"
... Actually, it's not a ditch, it's more like a 12 foot, 70 degree embankment with a small stream at the bottom
When it happened I went straight down the embankment and ended level at the bottom, so there was a fairly substantial impact on the front suspension. We got a tow truck to pull us out, but when I put the truck back in drive, nothing, just a whirring noise. When I pushed the button to engage the front AND rear, the rear tires ONLY will spin. Looked under the front end, and yellow gear oil was POURING out!
I drove it a few block to get it off the road and where I could look at it closer, and sure enough, the front diff third member casing has a large split in it just to the right of where it mounts to the underside of the truck.
So, I have a few questions...
1. Can I drive it home or to a shop to have the new parts put in, or will driving it (very slowly) will do more damage?
2. What parts will I most likely need? I've read a lot about the ARB. Is that a viable change to make at this point? This is not a wheelin' rig, so not sure if it's needed, but if it's not a whole lot more $$$, then may be worth it for the added strength.
3. Any suggestions on WHERE to pick up the parts? Price and availabilty are the main factors
4. How much out of pocket am I looking at to get this fixed?
5. Is there any potential of more damage? Any things I should be looking for?
Thanks for your help,
Raj
Raj
