- Location
- United States
Heavy duty slides. One Pair. Each one weighs around 25lbs. Different sites have different information, but it should hold around 220lbs each.
- Does not lock when extended
- Slightly locks when closed
Taken from website:
The Hettich KA3320 60" drawer slides are a heavy duty, telescoping, precision, full extension drawer slides for high loads, up to 500 lb. capacity, with cushioned in and out stops. Chromated steel.
The runner and ball race form a single non-detachable unit. Smooth action and high side stability through precision slide. Ball spacers made of noise-absorbing plastic with hardened steel balls.
3/4" Installation Width - 3" Height. Tested Weight Capacity: 220 lbs. @ 10,000 Cycles - 143 lbs. @ 75,000 Cycles. Cabinet member requires #10 Flat head countersunk screw. Drawer member requires #10 pan head screw. Screw length will vary depending on application. Use all screw holes to acheive full load rating.
Reference:
Amazon.com: Drawer Slide, Full Extension, 60 in., Heavy Duty, 500 lb. Capacity, Zinc: Kitchen & Dining
https://www.ovisonline.com/Assets/PdfS/Hettich/KA3320.pdf
I bought 2 pairs, but I think I will only use one set.
$125/Pair. Pick up only in Oakland or Alameda. No shipping
Taken from website:
Reference:
