hello all my first post 1987 cruiser bj74 13bt 3.4 l turbo diesel frp top 5 speed manual on 15x8 steelys with cooper 33inch srt pro s.. Soft brake pedal just a bit of history all recently done.. recon master,new slave, rotors and pads all workin well then did overdue front knuckle seals,new wheel bearings king bearings etc calipers were detached so bled system and pedal soft so after more bleeding with no result and bit of head scratching i went to the rear. lh cylinder leaking so new cylinders and shoes both sides..still cannot get gd brakes pedal still soft and does firm up wen pumped but cannot find any fluid leaks ? please help brakes were gd previous to original master cy issue thank u
I tried the old pump and release method to bleed my soft pedal and only got slightly better
Had to use brake fluid pumped through under pressure and hey presto got a nice hard pedal, must have been a small airlock somewhere
I had the same issues. Suction bleeders did not work.
I made my own pressure bleeder. General instructions were Google-able.
Pressure bleeder's master cylinder "cap" is just a plate of 6mm aluminium tapped to accept pipe/hose fittings. Sheet rubber for gasket.
An adjustable strap holds the whole mess tight onto the master.
One thing I thought might help was to get the arm of the LSPV gizmo on the rear axle free and work it up and down while bleeding fluid.
This made no difference for my truck.
hi all just a final post to this problem in case it helps anybody in the future..had a mate of mine check it out as i was against the wall and he discovered the wheel bearings had play [even tho had previously replaced them had not quite snugged them up enuf] so he adjusted them prob only half a turn and then quickly bled the front brakes and wow solid as. the stopping power is now awesum and all workin well so the little movement cos the bearings not tite was not allowing the brakes to be properly bled !! i was so happy as would have never come to that conclusion on my own cheers
