I know this topic has been discussed here before and I have searched and found some good information, however I have some questions.
Vehicle: 1984 FJ60 stock 31x10.5 tires
I have 1994 4Runner calipers from wrecking yard
I have 1990 PU 1” Master Cylinder from wrecking yard
Should I rebuild the calipers and master cylinder or by remanufactured?
If remanufactured what company?
I plan on changing all the brake hoses to stainless steel, SOR sells a kit for the 60 however I think the hoses that go from the axel to the caliper will be the wrong length if I bypass the dust shield.
What is the correct length of hose to use when bypassing the dust shield?
I know the NAPA numbers but don’t know what the length is.
Napa # 38881 (longer)
Napa #38878 (shorter)
Where is the best place to order stainless steel brake lines?
What are the fittings called and what size are they in case I find a local shop that can make them for me?
The hoses that go from the frame to the axle would be OK in SOR’s kit but within the next year I plan on lifting it about 2.5”.
Would it be OK to go ahead and install the longer hoses from the frame to the axle?
I don’t want to have to buy new hoses again in a year if I don’t have to.
I plan on doing this upgrade over the spring break, (no I don’t get spring break but the wifey does and I can use her car over the break while the truck is down) so I need to get the parts ordered and everything together before then.
Thanks All
Greg
Thanks All
Greg
