Howdy,
I have a few tech questions regarding my 45, I hope someone on this exceptional site can help me with my questions.
1. I have the double brake resevoir set up on the master cylinder. Recentley on a camping trip I lost brakes when the L/H brake line sheared off at the flared end and fitting near the wheel hub. ( being old and rough road corrugations)
Any way the brake warning light did not come on at all, I all knew was the pedal went to the floor. Thankfully the second resi held enough to limp home.On closer inspection there are no wires coming off anywhere from the resi's.
Is it a globe, fuse or lack of wires ? I am not sure how it knows its empty. The later 75 series had a float / sender and wire arrangement in the rubber dust cap. Does the wire connect to the bottom of the cast manifold directly below the resi's.
Anyone got a photo of the set up ?
Q.2. I have also noticed quite a lean on the R/H drivers side.
could that be the springs and shocks are shot. I did replace the bushings and replaced the broken fender bolts on the chassis. ( I thought the problem was body lean and old spring bushes)Most of the weight is on that side. The driver, the fuel tank, the transfer case, battery. Would that make a difference ?They are relativley old ,Anyone have any suggestions?
Any help would be most appreciated
NTFJ45
NTFJ45
NT
