In certain circumstances, when I push the brakes on my '04 LC, I get a shimmy. This happens most when I'm moderately slowing down from a pretty high rate of speed. If I'm on the freeway and I use the brakes to slow from 65 MPH to 40 MPH I get a shimmy. If I jam on the brakes for an emergency stop, no shimmy.
In case it matters, the LC is stock except the torsion bars are adjusted to level it out. I had the stinkbug stance pretty bad. There is no diff drop.
I'm thinking of getting my rotors turned to address the problem. The problem is I have lots of pad life left. Is it pointless to turn the rotor without putting in new pads? Also, am I better off putting in a new rotor rather than turning the old one? How much labor time should I expect the shop to charge to turn the rotors?
I'm actually hoping to kill two birds with one stone on this one. I've got a knock that comes when I first hit the brakes (and only when the brakes are warm). I know it's not the common drive line thunk (I've gotten that under control via lubing) and I don't think it's a suspension problem because I don't get the knock going over bumps, etc. Perhaps when they disassemble and re-assemble the brakes they'll find that a vibration damper or shim or something was put previously incorrectly installed and they can correct or mitigate the problem. If anyone has any other suggestions on this, I'm all ears.
Thanks in advance!
Thanks in advance!
