My brakes have been starting to stick more often at end part of the depress stage in the braking cycle. While depressing the brake it feels like it is rubbing against something and then lets free. This has started to happen more frequently, so I took it to a local Toyota Dealership. After four hours the service advisor called me and said I would require a new "Brake Computer Unit" for 3,0000 installed. He had mentioned that the braking is completely electronic and there is no Master Cylinder or Booster. He mentioned that the computer was not "computing" correctly and not letting up the pedal, and then resetting to release. They were not sure if that was the problem but wanted to charge another $250 to research it more on top of the $55 charge to diagnosis. When I received the Quote I got a part number and the part name was changed to Brake Actuator. I researched the part online and it mentioned the part was a new Master Cylinder and Booster. At this point I am completely confused.
My question is could this be a mechanical problem? And if so can the part causing this be replaced or rebuilt instead of a 3k investment?
Any help is greatly appreciated!
