97 non-triple locked.
Since I bought it I have been fighting the incredibly long pedal travel before engagement. The pedal goes until about basically the last 2-3” before starting to slow. Engages great from there. But to hold a stop the pedal is so low you can barely get your other foot behind it. Here is what I’ve done so far. I am losing my mind over this.
Bled the crap out of it to the point it was basically a fluid flush. Did this with pressure and 2 man.
Found a leaking bleeder valve after flush so I replaced all 4 calipers. Then bled it again. No improvement.
Deleted ABS and LSPV in case that was causing the issue. Bled the system again. No dice.
Brake master was replaced so I pulled off and checked clearance from booster. Thought I fixed it because brakes were great! But turns out the rears were partially engaging and holding. The booster was definitely not oem or oem style. It had 3 vacuum holes, 1 of them plugged and the arm had a lot of “free play”. So I installed a new booster and made sure the adjustment was correct. Bled system again. Still nothing.
I am out of ideas here. Is there some pedal adjustment I’m missing??
