my brake light came on a week or so ago. fluid looked a little low. i figured the pads were just worn enough to lower the level in the master.
i bought new pads yesterday (hard to believe pads from the dealer are cheaper than pads from schucks/kragen).
jacked it all up and all the pads look fine, no sign of fluid leaking anywhere. only odd thing is the rear drivers rotor is more worn on the inside than the outside. is this a bad caliper or just stuck slide pin?
still doesn't explain why the brake fluid level has gone down enough to trigger the light.
should i replace both rear rotors? or just the one that is unevenly worn?
