I'm wiring up a brake controller into my 60 series wagon. It's 12V. I've done this twice before, and I keep wondering why does the 'BLUE' wire from the controller to the 7 connector plug ALWAYS corrode so badly? My understanding, although vague, is that the power from the battery is fed into the controller, and then this continuous power is fed from the controller to the plug through the Blue wire. Is this correct?
I know it's pretty straight forward as far as wiring, but I'm tired of having to replace plugs that are corroded right through. Would it be a good idea to put a switch on the blue wire when the controller is not being used to prevent continuous charging of this wire, and would that alleviate the problem?
