- Year
- 1996
- Vehicle Model
- 80 Series
- Location
- Boulder, Colorado 80305 United States
- Mileage
- 273000
- Color
- green
I'm planning to list my 1996 Lexus LX450 with a fully rebuilt and supercharged 1FZ-FE on BAT in January but thought I would list it here first to see if I could avoid their fees, etc. for both parties and save little time.
It has been built for durability and extended overlanding with trips to Canada, Mexico, and throughout the western United States taken confidently. It’s been my daily driver for nearly ten years and anything that has needed to be addressed (or upgraded for that matter) has been. The majority of the work has been completed at Slee OffRoad in Golden. I have records for all aftermarket additions and maintenance through my ownership and many through the prior ownership dating back as far as 2009. The vehicle has never been in an accident, is rust free, and has been correctly maintained regularly.
The engine was rebuilt around 197K miles by PowderPig/Robbie Antonson following a head failure. A TRD/Magnussen supercharger, landtank supercharger orange fan clutch, ARB twin compressor, front and rear differential air lockers, and nitro 4.88 gears were added at that time. The undercarriage was stripped and raptor lined in 2016, a 4x4 labs rear bumper and a Costa Fabrication front bumper were both added in 2018, an OffGrid 4x4 dual battery system and electronics were added in 2019, the axles were fully rebuilt, sandblasted and painted with chassis paint in 2020 by Slee Offroad, it was repainted Toyota 6V7 in 2020, a Slee suspension system and Baja Designs lighting added in 2020, and a redhead sector 105 steering box added in 2023, among many other items.
I'm asking $32,000. Additional photos and videos can be found here
I'm selling because I've owned her ten years and I'm ready for something new, sadly. A tough decision but I have already purchased her replacement, a 2020 Land Cruiser, to continue on with the adventures.
Drivetrain
Robbie Antonson (Powder Pig) Engine rebuild @ 197,351 - Piston & Rings Cryo’d; Restored proper variances and load-bearing capacity (0.25 rod & main bearings; 1mm piston overbore), Full detail available
Ceramic coated headers
Magnusson Supercharger 02-90-45-003-SL
Landtank1FZ-FE HD Orange Hub Fan Clutch for a SuperCharger
Red-head steering gears Upgraded Sector 105 Sector Shaft/Pitman Arm
ARB Front & Rear Lockers
4.88 Nitros gears
2020 full axle rebuild @ Slee
ARB Breather Kit
Exterior
Costa Fabrication Front Bumper (Powdercoated)
SOF Aluminum Hawse Fairlead - 1" Thick - Military Grey Hard Anodized
Factor55 - Flatlink E - GRAY
Warn Zeon 12-S
4X4 Labs 80 Series Rear Bumper (Powdercoated)
4X4 Labs Ladder Attachment
4x4 Labs Two-can Attachment w/Hi-lift Mount
4x4 Labs Tire Attachment
Custom Steel Sliders
Custom Steel Catalytic Converter Protection
SAFARI Snorkel
YotaTEQ Gullwing Hatches
Repainted 2021 Toyota Army Green (6v7)
Undercarriage stripped and raptor lined 2016
Wheels & Tires
Method 703s
Spidertrax Wheel Spacers
35" Toyo Open Country ATIII
Suspension
SLEE - Front Coil Spring - Medium
SLEE - Rear Coil Spring - Medium
SLEE - Remote Reservoir Shock- Front
SLEE - Piggyback Reservoir Shock- Rear
SLEE - 2" Rear Bumpstop Drop Blocks
SLEE - 2" Rear Bumpstop Drop Picks
SLEE - Billet Front Control Arms
Delta Vehicle Systems Rear Panhard Lift Bracket
Whiteline 30mm X heavy duty sway bar and bushings
SLEE - Steering Drag Link
Interior
Back Bay Customs Tailgate Storage Panel
Rosen Visors
DVS 95-97 DASH CUBBY INSERT
DVS A-pillar mount
DVS Useless Ashtray Replacement
DVS Anti-Rattle Mount
DVS Shifter Console
DVS Locking Center Console
MICTUNING MIC-DV-077 LED Digital Panel Double Voltmeter
DVS Modular Rearview Mirror arm
Gentex Rearview Mirror
Toyota Center Differential Lock Switch
Extended Remote Antenna Mod
Gamiviti Seat Gears
Trekboxx Alpha System
Trekboxx Second Row Platform
Weathertech Front Mats
Husky Middle Mat
Blue Ridge Overland Attic
Blue ridge Triple Run Headrest Panels
Blue Sea 12v Cig USB
Victron solar controller
Front and middle seats re-covered and new foam installed 2016
Door Armrests re-covered 2016
Electronics
RedArc BCDC1225D In-Vehicle Battery Charger
Slee Dual Compressor mount
ARB Twin Air Compressor
ARB Manifold Kit
Sunflare 180W Flexible Solar Panel
Victron charge controller
Offgrid 4x4 dual battery
Battery bridge & in cab switch
Switch-Pros - SP9100 8-switch panel power system
Midland MXT400 GMRS Radio
Firestick Antenna
Baja Designs - LED, Dome Light w/Switch - White & Red on Liftgate
Baja Designs - LP6 Pro - Driving Combo - White
Baja Designs - LED, Rock Light - White
Baja Designs S2 LED's on GFC
Miscellaneous Repair Items
Passenger side vent 2024
Driver side mirror 2020
Power steering pump in 2022
Catalytic Converter 2019
Factory speaker with Pioneers
Hi-lift mount re-welded and painted 2025
Radiator in 2025
Known issues
The steering wheel and driver's side seat show wear
I need the switchpros controller serviced - minor grounding issue. Lights are currently operable
Paint imperfections though the new paint job and ceramic coating has held up well
Surface rust on orange front bumper shackle bolt
Radio antenna deleted
Has the Pioneer Head Unit I installed in 2016. It's due for an upgrade
Excluded from the sale
V1 GFC RTT
These are available separately should anyone have any interest or could be negotiated as part of the sale of the truck.
Happy to answer any questions, take additional photos, or schedule tour for those interested. I plan to take more detailed photos once I receive the truck back from it's servicing.
Tanner
Drivetrain
4.88 Nitros gears
ARB Breather Kit
Exterior
Warn Zeon 12-S
SAFARI Snorkel
Wheels & Tires
Method 703s
Suspension
Interior
Rosen Visors
DVS A-pillar mount
DVS Shifter Console
Gamiviti Seat Gears
Husky Middle Mat
Electronics
ARB Manifold Kit
Firestick Antenna
Radiator in 2025
Known issues
V1 GFC RTT
Tanner
